Tool Talk Discussion Forum
string trimmer
Mike S
08-24-2003 11:42:08
I bought a Homelite straight shaft string trimmer.
The ?gear box? just above the trimmer head seems to get really hot. Is there a way to lubricate this part? Should I use oil or grease? Thanks
mikethetech@mail.com
Trevor
08-24-2003 15:01:19
 Re: string trimmer in reply to Mike S, 08-24-2003 11:42:08
If it is new take it back. I had a Ryobi that did that. I went through 2 heads before I sold it. My new Styhl doesn't get hot.
bill
08-24-2003 14:42:45
Mike, is it new? is it used?
i have a "weedeater" brand trimmer. it gets hot there too, but not hot enough to burn up. there is no way to lube the assembly on mine.
it is a gear box, so some heat is normal.
BillW
08-24-2003 15:35:34
 Re: Re: string trimmer in reply to bill, 08-24-2003 14:42:45
I assume you have the black 'curved' gear head. It is the lowest price head HOMELITE uses and is not considered 'serviceable'...BUT since the more expensive aluminun gearhead has instructions to use a good lithiun grease every 100 hours, I would VERY carefully take the head apart and regrease it at least every 50 hours.
