Tool Talk Discussion Forum
shop electricial question
James in North
11-23-2003 17:51:55
I'm converting part of the garage in my new house into a workshop. I want to add two new outlets each with its own breaker to run drill press, table saw, etc from.
I'm not sure if I should use 30 Amp or 20 Amp breakers. Any drawback to the 30Amps?
Also, what is the difference between single and double pole breakers? Many thanks. James
Greg Or.
11-24-2003 21:33:13
 Re: shop electricial question in reply to James in North Carolina, 11-23-2003 17:51:55
HI Jim
I'm alway refering to to this book just for the line drop tables alone.
'Wiring Simplified' by H.P.Richter and W.C.Schwan ISBN 0-9603294-7-1
This book is based on the National Electrical Code, it 5.5" x 8.5" 225 pages or so and lists for $9.95 + $3.00 S&H or $12.95 1-800-841-0383
D.L.
11-24-2003 21:16:31
I see there's a ton of experience already recorded here, but I'll throw my 2 cents in anyways... First, it's difficult for anyone to tell you to "Use #12 wire." The CORRECT wire size is a function of the amount of current carried over a given distance... period. If you have a relatively light load, and your wire run is only a few feet, a #12 wire may be fine... but, increase the load and/or the length of the run and you've got trouble. Ideally, you want to size the wire so it carries the desired current with less than a 2% voltage drop. There are a number of reference books on the market with charts to help you determine the correct gauge wire. Secondly, when I wired my shop, since I ran all the wires inside the walls (where they're not easily changed) I tried to anticipate the type of equipment I MIGHT use some day, and sized my wire accordingly. My shop is extremely long and narrow, and I ended up with a 7 1/2 hp air compressor (which pulls a ton of current) so I was GLAD I installed the #6 wire for my main run on that circuit. I definitely don't worry about overload or overheating the wire. The only drawbacks to the heavier wire are that it is a bit more expensive (but worth it if you're going to stay in your place for a while) and it's a bit more difficult to work. But, once it's in... no worries!!! If you've installed a heavy enough wire, you can change breakers as your needs change.
thurlow
11-24-2003 14:15:00
James, haven't read all of the posts, but I've found this to be a valuable forum:http://www.selfhelpforums.com/
Ernie Kenward
11-24-2003 12:58:09
Whatever you do, do it according to the requirements of the National Electrical Code, as it applies in your region. National codes often are subject to local ordinances. If you are in doubts as to this, secure the services of a licensed electrician.
What size of service to put into your shop would depend on the size of the loads you intend running and, to a lesser extent, their frequency of use.
A basic single-pole 120V 15A circuit, ground-fault protected, is the basic code requirement for a basic garage, and would be adequate for running basic hand tools and low-power drill presses.
A "working" garage would probably do best with its own sub-panel. A 30A 240V panel can offer up to four 120V 15A circuits, or two of these along with a 240V 15A two-pole circuit suitable for a small-size 240V MIG welder. There are a number of light-duty MIG welders about (Century 105, for example) that run on 120V for "convenience" but these really do require a minimum of 10awg wire (larger if the run is more than about 20 m) to handle the current thermal load and limit the voltage drop) and would of course require a 25A or 30A breaker; this would be single-pole in the case of a 120V welder.
Note that "double-pole" breakers are there to service 240 loads, and/or to assure balanced use of the incoming service. 120V loads use one side of the utility transformer only, and the main panel distributes such loads more or less evenly on both sides of the transformer center tap. 240V loads use the full secondary winding. Heavy loads on one side of a transformer only cause hot spots and power quality problems and shorten transformer life.
Good luck with it.
E G Kenward
senior member, IEEE
senior instructor,
Power and Industrial Control
School of Electrical & Computer Engineering
BC Institute of Technology, Burnaby, CANADA
Willy-N
11-24-2003 08:34:43
Just a point to help. All standard 120 volt 3 or non grounded 2 prong plugs like you see in your house should be at least a 15 amp and can be 20 amp. Tools with regular cords like you have on your coffie pot, freezer, toaster and such run on 15 amp circuits. A true 20 amp cord end will have a prong that is 90 degs to the other one unless it is a twist lock. Now your kitchen outlets, Washer and a few other applances go on 20 amp circuts even tho they have 15 amp rated plugs on the cords. 30 amp circuits are for seperate devices like dryers, range tops, welders, large saws, big compressors and such and have special plugs or hard wired. Never wire 30 amps to regular style 15/20 amp 120 volt outlets. It can damage the equipment with the style of plug for the 15 and 20 amp loads if a problem happens to over load the device. This is why there are different styles of plugs on the ends of cords they dictate the amps and voltage needed for the equipment and is called NEMA Configuations.
Leroy
11-24-2003 07:01:46
There are both 110 and 220 in double pole breakers, the 220 double pole breaker is 2" wide and needs 2 spaces while the double pole 110 breaker is only 1" wide and fits in the same slot as a standard single breaker, they are designed for use in a box with no more space to ad an aditional breaker so by changing a single 1" with a double 1" you have an aditional circut avaible and you have to match the brand of breaker to the brand of the box
John K
11-24-2003 07:32:17
 Re: Re: shop electricial question in reply to Leroy, 11-24-2003 07:01:46
Sorry to break your bubble. Been an electrician for over 30 years and have yet to see a 110 (125) volt double pole breaker. A single wide breaker is a single pole, a single wide breaker with two trips is a tandam breaker but still is considered a single pole. You have to remember that these tandem breakers do not have thier trip mechanizims tied together and are on the same hot leg of the panel. To qualify a breaker to be double pole or triple pole breaker, thier trip mechaniziums must be tied together in such a way that if one pole of the breaker trips that the other poles of the same breaker trip also. A two pole breaker is connected to two diffent hots (legs) and a three pole breaker is connected to three different legs. By the way, just because a breaker is a double pole doesn't mean it is 220 (240) volts, it can be 480 or 600 volts. Same applies to three pole breakers.
MC
11-24-2003 13:27:34
 Re: Re: Re: shop electricial question in reply to John K, 11-24-2003 07:32:17
No bearing to this but there's 110 volt breakers that take up two spaces . When you feed a gas pump you get a breaker that breaks both the hot and the neutral . and it looks like a two pole but has a neutral wire on it . Used them many times .
George
11-23-2003 21:15:41
A couple power hogs like a radial arm saw and a shop vacuum, if plugged into the same 20A breaker, will probably trip it. If you are going to the trouble of wiring your shop, go ahead and use two 20A breakers wired to multiple outlets.
Wayne
11-23-2003 21:10:31
Hey James, I just read the replys to your post and they offer alot of good advise. Unless you have a huge drill press or saw then a 20 amp wired in with #12 should be sufficient. Look at your motors and see what the rated full load amps is at the voltage you intend to use, in your case I'm guessing from what you said your running on 120volts. You can usually expect at least 1.5 times that as the starting amps. So unless they are huge motors and you intend to start both of them at the exact same time on the same recepticle then, like I said the 20 should be more than enough. Like one of the other posts said, the breaker is only to protect the wiring, not the motor, so it's not gonna matter if you have more amperage available than the motor needs. A GFCI is a good thing to have, and I believe it is code, in a garage. I guess they expect you may some day be standing in water using power tools. Since your making a seperate hobby room and not a garage, I don't think their need anymore than they are in any other "regular" room in your house, but if your worried about it being "code" you can call the inspectors and ask. If you do use the GFCIs I believe you'll find before long that that they simply won't hold up to the starting loads placed on them by power tools. I took the test in Cabarrus Cnty, NC. 4 years ago, when I built my shop, to allow me to do my own wiring and to have it inspected to code on my personal work instead of hiring an electrician. I wired in a couple downstairs in my shop//"detached garage" to please the inspector, but I did the upstairs with regular outlets and nothing was said about it at the inspection. Just make sure if you run a 20 amp breaker that you get the outlets to correspond to the higher amps also since some are only rated to 15. Something else that is code around here is they no longer allow you to "legally" plug the wires in to the outlet, you need to use the screws. Usually this isn't an issue when you use #12 anyway because the holes are designed small for #14 but just in case, now you know. Just remember if in doubt, call a real electrician because even though you can't see it, electricity is mean. It won't hesitate to kill you or burn your house down, or both. Good luck and above all be safe.
buickanddeere
11-23-2003 20:11:04
15 amp breakers on 15 amp U-ground receptacles. If you are tripping them then it's oveloaded. I prefer the GFI at the bench rather than back at the panel.
Neal-WI
11-23-2003 19:06:50
For shop tools, install a 20 amp breaker. (use #12 wire) It may now be code to use GFIs in your garage. You can either use a GFI breaker in the box, or install a GFI outlet as your first outlet after a standard breaker. Any regular outlets installed after the first outlet will also be protected, but when and if the GFI trips, it needs to be reset at the first outlet. To work properly and safely, the power from the breaker MUST be hooked up to the "line" terminals and any other outlets to the "load" terminals. Instructions will come with the outlet.
old
11-23-2003 18:05:40
Well with a 30 amp you should use #10 wire and a 20 amp # 12 and if I understand what you are asking a single pole is 110v and a double is 220v
11-23-2003 18:19:51
 Re: Re: shop electricial question in reply to old, 11-23-2003 18:05:40
Thanks Old. You answered my question about single and double pole breakers perfectly. Now I finally know the difference between them. Any opinion as to weather 20 Amps is adequate for power tools?
Many thanks. James
GG
11-23-2003 18:43:13
 Re: Re: Re: shop electricial question in reply to James in North Carolina, 11-23-2003 18:19:51
Just realise that the breaker protects the WIREING SYSTEM. If you use 30 amp breaker with # 12 or smaller wire, you stand the chance of melting the wire resulting in a possible FIRE. For personal safety, against shock, I would recommend installing GFCI recepticles or GFCI breakers. Cheap insurance that might save your life.
11-23-2003 18:58:36
 Re: Re: Re: Re: shop electricial question in reply to GG, 11-23-2003 18:43:13
Hey GG, I priced GFI's at Lowes today. The 20 Amp were about $12. I agree, that's some good insurance for not too much money. Thanks. James
old
11-23-2003 18:37:02
Most of the time they are and I know when I wire up something I prefer to put in breakers that are a little small. That way your a little safer I'd rather trip a braker then burn something down. I had a welder on 30 amp breaker and never had trouble unless I turned it all the way up. Hope this helps you some more
11-23-2003 18:53:18
 Re: Re: Re: Re: shop electricial question in reply to old, 11-23-2003 18:37:02
Thanks Old. Your information has helped a lot. Sounds like 20 Amps may be the safest way to go. Thanks. James
paul
11-24-2003 11:57:45
 Re: Re: Re: Re: Re: shop electricial question in reply to James in North Carolina, 11-23-2003 18:53:18
I didn't look at all the above messages.....
Your question it one that brings out all kinds of replies: It sounds like you don't know a whole lot about electricity, and just want to put some stuff in to make it work. So please take the rest of this in the firendly spirit it is offered, from another person who would like to do some wiring but doesn't know allt hat much about it:
Please be careful. It is pretty easy to hook up wiring that makes a light go on & off, or makes a drill work when you plug it in. But it's _real_ hard to make everything meet code, be safe, and put all 4 wires to the proper connections all the way through if you don't understand the concepts. The drill will operate even if you mix up the hot & neutral wires - the drill will operate if you confuse the nuetral & ground wires. It will operate if you don't connect the ground wire. But, all of that makes it really unsafe for you & others. A shop tends to have sawdust, tools, metal, paint fumes, liquids, and so forth pile up.. Person works when it's cold or dark or after hours when you are tired..... And that's when the electrical 'mistake' will show up - when you are standing in a puddle of snow melt and grab the improperly grounded drill. If you connect the ground to the wrong place, you could mess up the ground for your whole house, not just the 2 outlets you put in...
There are lots of local codes, I'll bet you are covered by some. They may or may not make sense - but are the law. But you should at least understand the national electrical code that applies to what you are doing, and follow that. It really, truely, is there for your safety. The national code mostly does 2 things - keeps the wires from melting & burning down your house, and keeps you & your family from being a conductor of any electricity _if something goes wrong_. If you don't know what you are doing, you really won't know if you got it right until _something goes wrong_. Could be years from now.....
So, do it right, do it to the national code. Understand that much. By law, you need to follow local codes.
If the house burns down & the wiring was wrong, your insurance company might not pay if you didn't follow all codes.
If a family member gets hurt, how will you feel?
To answer your questions a bit, from someone who doesn't really know too much: I think all consumer grade wall outlets at 110v are rated for 15 amp or 20 amp. I don't think a 30 amp breaker would be proper, as the wall outlet could overheat & fail at 30 amps, and the breaker would not be protecting you. If you have a 220 load - welder, air compressor, etc. - then this does not apply.
I think the single/ double throw was covered already, 110/220 power.
For a shop, it is wise to use a size thicker wire to cut down on line-resistance loss. Really helps your motors last. But you need to start in the main power box & make sure all the wire is at least that size - don't tap into a #12 wire with a #10 addition.....
--->Paul
Willy-N
11-24-2003 16:10:03
 Re: Re: Re: Re: Re: Re: shop electricial question in reply to paul, 11-24-2003 11:57:45
Good points and one of the reasons I realy do not like telling people how to hook things up electricaly. You have to do it right to be safe that is what the codes are for!! Mark H.
11-24-2003 18:42:22
 Re: Re: Re: Re: Re: Re: Re: shop electricial quest in reply to Willy-N, 11-24-2003 16:10:03
Many, many thanks for the help guys. It's nice to see so much knowledge in one place.
Actually I've put in wiring for stoves, attic fans, shop lights etc., but never outlets for bench tools. To me, building code is the minimum guideline I would follow. I wanted to see if more experienced hands would go beyond code requirements.
Later this week, I will put my first diagram on paper, put it away for a couple days then look at it again to see if I want to make any changes.
I spoke with a town inspector and he said that 20 Amps on each circuit would be fine along with 12 gauge wire. The also suggested GFI breakers in place of GFI outlets.
The tools I'm looking at running are rated at 15 amps, but I was concerned about the startup amperage hence the question about 30 amp breakers.
I also understand the reluctance to offer specifics on working with electricity, especially if you are a pro. A reader should always verify anything read from the internet, but nowadays people are so eager to sue that any advice givers have to be careful.
I do appreciate the help.Thanks
James
Willy-N
11-24-2003 19:27:55
 Re: Re: Re: Re: Re: Re: Re: Re: shop electricial q in reply to James in North Carolina, 11-24-2003 18:42:22
Don't worry about the start up current. Breakers take a while to trip due to over loading at around 125 to 150 percent. They will trip fast due to short circuits. You could draw 30 amps on a 20 amp breaker for a while befor it trips that is why they like you to use motor over load protection or rated motor fuses to protect them. Worry more about long runs being a small gauge like 14 Gauge wire when it should be #12 or #10 for the distance to keep your motors from running under voltage. Breaker size is not as important unless you over size the breaker for the wire rating. Mark H.
T_Bone
11-24-2003 22:20:50
 Re: Re: Re: Re: Re: Re: Re: Re: Re: shop electrici in reply to Willy-N, 11-24-2003 19:27:55
About 25yrs ago I went to check out a new owners (older home) refrigeration equipment. When I did the air handler inspection, the "fused" load center (located outside of the house) was with-in sight so it didn't have a unit disconnect at the air handler.
When I opened the load center door I found that all circuits were fused with 30a fuses and had been recently done that way.
I asked the owner who had changed the fuses to 30a and he said he did as his "brother" was a sparky and told him it would be the best thing to do. (ya, right, I was not born yesterday and didn't fall off a tomatoe, no a carrot, I mean a turnip truck)
Naturally I told him he needed to change them back and why he needed to do so. I noted this on my repair order ticket.
Next morning at 6am, I get a call from the home owner saying the air handler was on fire. "What are you calling me for, call the fire department and I'll be there"
Upon inspection, the fan motor had shorted out and since it was still fused with 30a fuses, hence the motor "total melt" down. It also melted about 18" of lead wire.
Now the day before I ran a motor voltage/amperage check, check the bearings, checked the fan belt and alignment, checked for loose electrical connections, etc, anotherwords I did my job.
It was just amazing how those motor bearings seized up when the unit did not call for either heating nor cooling over night as I had left the thermostat in the off postion, and I also pulled the 30a unit fuse, and noted the above on my repair order.
Can we say insurannce fraud!
The insurrance adjuster didn't buy it either.
I did however find it interesting on what did happen with a 115v circuit on a 30a fuse. The fuse was not blown as the wires had burnt off the motor terminals.
T_Bone
Willy-N
11-24-2003 23:00:29
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: shop elect in reply to T_Bone, 11-24-2003 22:20:50
Good old locked rotor curent draw! Most people don't understand running load, starting load and locked rotor load. Running load being what it draws when running under normal load, starting load is just that, the starting load and can be as high a 5 times and low as 1 1/2 times the running load depending on the classificaion of the motor. Cheap imports have higher starting loads. Now the locked rotor (shaft not turning) that can be real high! That is where the fusing realy comes in handy!! It better be lower then the lock rotor current draw or fires will happen. The 125 percent rating on the fuses will cover that along with time delay. The over load protection set for the motors running load (Heaters in the motor starter)will protect the motor from over working it. They also have a time delay to not kick out the startee for short time over loads. And the list goes on. I wonder why electricians get paid so much? Hope the old mind has not forgot to much been a while doing comercial wiring haveing been a Electrical Contractor for 13 years and a electrician for 30 plus but been out of the trade for at least 8 years and the old saying use it or lose it means just that! Mark H.
paul
11-26-2003 21:48:53
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: shop e in reply to Willy-N, 11-24-2003 23:00:29
Whew! Was worried I'd get blasted for something I said with this many replies below mine... ;)
Enjoy the stories you guys always have on electrical items. Really adds a lot to the table. Thanks.
--->Paul
