Stove fuel is #1, Furnace fuel is #2. These are old carried over terms. #2 will give you more heat at a cheaper price, however since you mention mobile home - don't even think about it. First off, you have an outside tank, so you need the flowability of the #1 Sove fuel. Secondly, if you have a smaller mobile home (vs. a double-wide) your nozzle in your funace is probably going to be a .50 or .60 gallon nozzle. (Perhaps in Canada they use different numbers?) Anyways that means that your furnace can burn .5 or .6 gallons of fuel per hour with that nozzle. All fuel nozzles orfices are tiny, but in comparison those are extremely small and they have a tendency to plug up much faster than those in a bigger furnace. The #1, while not necessarily cleaner, is for lack of a better term, more pure. It won't plug your nozzles nearly as fast just because it is thinner basically. So no. Your supplier isn't trying to make an extra dime on you. He actually knows what he's talking about.
