Tool Talk Discussion Forum
tire chains?
charlie
01-17-2004 12:56:50
need some help guys.got a pair of tire chains hanging on the wall in the back shed.i know there off a ford but don,t know what size they are.i'm 46 and they been there as long as i can remember.dads not here anymore so i can't ask him.anybody know how to measure them to determine what size they are?
charlie
01-18-2004 12:43:52
 Re: tire chains? in reply to charlie, 01-17-2004 12:56:50
the're for tractor tires.
FarmerTom
01-19-2004 04:40:29
 Re: Re: tire chains? in reply to charlie, 01-18-2004 12:43:52
we build them too!
FarmerTom
01-18-2004 07:09:05
we build tire chains.
lay the tire chain out on the groung, all stretched out(not bunched up or twisted).
measure the length of the side chain and the length of the cross chain (including the hooks)
post these 2 measurements here or email me and i'll tell you what size tire they fit.
Bob
01-17-2004 13:53:42
Our local harware/farm supply carries bulk tire chain in 3 or 4 sizes. It comes in barrels, and when you go in to get a set of chains, they consult a chart, and, using you tire size info, are able to know which width of chain is needed, and how long it needs to be. They cut that length from the appropriate barrel of bulk chain, attach "hooks" to it so you can couple it around your tire, and your all set.
If you could find a place that had a chart like that, you could compare the length and width of what you have to their chart to see what tire size(s) they would fit.
Slowpoke
01-18-2004 22:46:48
 Re: Re: tire chains? in reply to Bob, 01-17-2004 13:53:42
Bob... maybe the next time you're at the hardware store, you could write down the tire chain company name, address and chart publication number, usually on the back, and post it on this site. Then we could all order a copy. Wouldn't they be surprised!!
Seriously, I have a bunch of chains (50-60 sets) I need to get sized, and it would be a big help to have that chart.
Thanks in advance.
Slowpoke
arthur
01-17-2004 20:39:05
if you take the wheel off your car and try to fit them on you will make do some how real simple
Ralph
01-17-2004 13:41:22
There are so many variations that the best way I know is to try them on a mounted tire. For example the same set of chains will fit a narrow 15" tire and a wide 14" tire. With the different profile tires available now there are many more possibilities. New tire chains often had a list of a dozen different size tires they would fit.
