Tool Talk Discussion Forum
shop press and pipe bender
old
01-31-2004 12:49:45
Well I posted a question in here a couple weeks ago about buying a shop press etc well I got a press yesterday and since there was 20% off all tools at the place I got the pipe bender also. Thanks for your help guys
Slowpoke
02-01-2004 18:56:35
 Re: shop press and pipe bender in reply to old, 01-31-2004 12:49:45
For thin wall conduit, use a conduit bender... make nice smooth bends without crushing. No sand or freezing needed.
Mike
02-01-2004 11:19:23
Old
Now's the time to bend that thin wall tube. Plug one end and fill it up with water and leave it outside to freeze. Then cut and bend.
Chester
02-01-2004 05:51:54
Assume your pipe bender is the one that pushes a shoe up between two fixed points using a hydraulic jack. If so, have you tried bending thin wall tubing such as electrical conduits and exhaust tubing in it? And what kind of a job will it do?? Thanks, I have often looked at those too.
old
02-01-2004 10:14:15
 Re: Re: shop press and pipe bender in reply to Chester, 02-01-2004 05:51:54
Well I haven't used it yet but the book says to fill the thin wall pipe with sand so it won't kink. I plan to use it for makeing trailers and bumper and maybe a few deer stands. I'm also going to try to make a coulp dies for square tubeing. I only payed $75 for it so thats part of the reason I jump on it
