Tool Talk Discussion Forum
shoud I get nibbler or shear?
Rick
03-04-2004 06:53:26
planning to do some sheet metal construction for a mchine, possibly a small production run if they sell. Will be cutting lots of 22 gauge, some 16 gauge, all flat pieces. Would a nibbler or a shear be the better tool for this (air powered)?
Rick
T_Bone
03-04-2004 11:37:24
 Re: shoud I get nibbler or shear? in reply to Rick, 03-04-2004 06:53:26
Hi Rick,
I like a Uni-shear for general flat SM work as it cuts tight arcs and is easy to cut straight lines.
Uni-shear, cuts like a pair of scissors but needs the left side of the cut lifted for relief while cutting with no metal loss. Easy to control cut line "once" you learn how. 16ga capicity but there's a 18ga capicity Uni-shear thats works well for bench work. Will self-feed sometimes (continue cutting when held in the correct position).
Double cuts, uses the scissor motion between two blabes and cuts a 1/4" waste strip out and 18ga capicity. Great for field work for cutting round and square duct and such. Easy to control with-in the line. Northern Tools incorrectly states thease are nibblers. They are not nibblers. Hard to make self-feeding.
Nibblers, takes a nibblet cut, small 3/32" x 3/16" nibblets, mostly used for heavy gauge metal, 10ga. Will self-feed easy making the line hard to follow.
T_Bone
buck
03-04-2004 08:31:17
for straight to mild curves with a very nice edge I prefer the shear. for tight curves circles and odd small shapes I prefer the nibbler but the edge is not as good and may require added work for a good finished edge. By nature of the tools the shear is a more dependable/ longer lasting tool. If you have alot of longer straight cuts the shear is faster and generates a lot less mess than the nibbler. One can't always replace the other so I suggest both.
LesWV
03-04-2004 09:00:13
 Re: Re: shoud I get nibbler or shear? in reply to buck, 03-04-2004 08:31:17
I would agree with Rick on getting both if possible.
When looking at a metal shear. Try to get the largest one that you can afford. Decent ones in the 52" range can be gotten for around $1000.00. Being able to cut large sections of sheet metal with a shear and then going back to do the curved sections with a nibbler will save you a ton of work and lessen wasted material.
