Tool Talk Discussion Forum
steel balls
Larry E
04-04-2004 19:59:26
I need to know where to get 4 .3437 or 11/32 inch balls .They are for 69 F100 ford truck ash tray.
philgreen
11-04-2004 14:45:50
 Re: steel balls in reply to Larry E, 04-04-2004 19:59:26
You need an old 6303 bearing, they have 11/32" balls. Also if you can find an 5303, that is a double row ball bearing and you'll have 14 of them
Rusty Jones/ The Mower Ma
04-13-2004 09:39:27
Say, have you checked the 3-5 h.p. Briggs recoil starter ball bearings? There are about 5 inside of the unit. just pry off the top cover of the starter unit, and, there they are! fish them out with a magnetic screwdriver, check them, if not right size, put them back in, put cover back on, and try something else! Rusty Jones
Bernie in MA
04-08-2004 18:24:58
Spray paint cans used to have steel balls in them. When my son was little 20 years ago he had me cut the tops off so he could get them.
Alvin NE WI
04-06-2004 18:28:58
I useda have steel balls years ago.
Steve
04-06-2004 11:08:57
Oh c'mon !!!! You guys gonna let this topic go by with a joke about "steel balls"?
What's the world coming to?
jeffpapier
04-05-2004 19:25:58
go to any hardware store that sells and/or repairs bicycles, that is where I got the size to repair my hydraulic jack.
LesWV
04-05-2004 18:53:19
If You wish to order steele ball bearings or any type of ball bearing.
If Boca does not have it. They do not make it.
You need four and they just sale them in bags of 100. So that will give you 96 good "bullets" for your sling shot.. LOL
Fern(MI)
04-05-2004 17:52:25
Don't nobody watch Red Green anymore? Duct tape it! lol.
MAC,IL
04-05-2004 13:47:46
Larry, plastic or nylon balls would work. Check a craft shop for these. Steel balls, we used to make Large ratchet type clutchs, we got the 5/16 balls from a local bearing outfit, but you had to have a quantity. As suggested before, pick up some old bearings, you can remove a seal and get a general idea of the size balls inside before you take the bearing apart. Been a long time, I no longer have books, but seems that a bearing book has the ball specs according to the bearing number, that might help.
Larry E
04-05-2004 11:27:21
I quit smoking 43 tears ago .I looks like hell with hole in dash.
Unimog
04-05-2004 09:35:36
My local bearing and seal shop carries a pretty
good selection.
Brian G. NY
04-05-2004 08:14:59
Larry, why not visit your local auto wrecker? If you don't find a junked truck of the right year, look for any Ford with that type of ash tray; a lot of the older cars had them and I would "assume" the balls would be the same?
KX
04-05-2004 07:51:56
Good time to stop smoking?
Earl S.
04-04-2004 20:40:15
Mcmaster-Carr part number for 11/32 quant. 100 is 9528K18 old cat the prices is $6.92 per 100 Chicago phone is 630-833-0300 Atlanta Sales is 404-346-7000
Gene Davis (Ga.)
04-04-2004 20:09:19
Try an electric motor repair facility, as they often have used ball bearings they take out of motors when rewinding and when they reassemble it they use new ones.
