Tool Talk Discussion Forum
Remington Powder Actuated Tool - Shell Stuck
David
05-12-2004 06:39:40
I have a Model 476 Remington Powder Actuated Tool used to shoot nails into concrete. My problem is that the fired shell is stuck and I have been unable to get it out. Does anyone know how to either disassemble the tool inorder to remove the shell or some technique to remove the shell? Any help will be appreciated.
MarkB
05-12-2004 19:18:41
 Re: Remington Powder Actuated Tool - Shell Stuck in reply to David, 05-12-2004 06:39:40
I ended up throwing mine out when that happened. That was the hammer-blow version, so it wasn't a lot of money. Still, I didn't think I had abused it that much.
Charles (in GA)
05-12-2004 07:34:08
Well, a .22 case is not that sturdy. if you can get at the breech (and I assume you can for loading it) you should be able to take a punch, etc and collapse the case at the rim enough to weaken it and get it out.
Charles
David
05-12-2004 07:29:47
You can't. The way it is made, when the shell is fired it drive a piston (rod) down and hits the concrete nail, driving it into the concrete. Thanks anyway.
John *.?-!.* cub owner
05-12-2004 06:49:03
This may be a dumb question, but have you tried inserting a rod in the end to push it out?
