120v Generator from Automotive Alternator
Bill
10-01-2000 06:28:18
Years ago I used to have a unit that would produce 120volts from a vehicles alternator with an external voltage regulator. Wondering if anyone has done someyhing similiar with an alternator that has an internal regulator? If so and you have any plans I would appreaciate it as I have some spare alternators and would like to make one up and hook it up to either a lawn tractor or spare signle cylinder engine for a portable power source for some of my tools.
Thanks..
Bill
ltf in nc
10-03-2000 09:51:15
 Re: 120v Generator from Automotive Alternator in reply to Bill, 10-01-2000 06:28:18
This is not the answer to your question but it will b permit use of electic tools at remote locations. Take the battery powered tools that are available, preferably yard sale sourced, and remove the battery. Fabricate an extension cord and solder it in place where the battery would make connection inside the tool. Get a couple of alligator clips an put them on the other end of the extension cord and hook same to the battery of the tractor, lawnmower, four wheeler, etc. Works good and will work all day if you have the vehicle charging occasionally. Shock hazard is eliminated also.
George Marquis
08-30-2002 16:50:24
 Re: Re: 120v Generator from Automotive Alternator in reply to ltf in nc, 10-03-2000 09:51:15
I have read several article on your request years ago.
Yes it works.
You disconect the regulator and connect your12 volts ( Battery ) direct to the rotor ( field ).
If you give it enough speed you will get prety close to 110 volts DC. You can use it for lights ( not fluorescents ) and universal motors ( with brush ) Not induction motors ( water pumps etc )
I have also seen using automotive alternators with small air cooled engine for welding. They work beatifully. One problem, they do not last. I sucpect it is because of the vibration. The insulation cannot take it. They short circuit. george
Ray Peterson
10-02-2000 17:26:53
Be aware that the regulation and frequency can be lousy- do not use it for anything critical! Maybe a drill motor or something like that would be OK.
Alternators driven by a small single cylinder tiller or mower motor make great 12v power for jumpstarting, or charging batteries, or powering 12v. appliances - but you should float them over a battery for this use.
Cal S.
10-01-2000 12:09:50
Bill, Northerntools sells a converter for this purpose.
Tim K.
10-29-2000 04:39:21
 Re: Re: 120v Generator from Automotive Alternator in reply to Cal S., 10-01-2000 12:09:50
Check out this website. I think it may help you.
http://theepicenter.com/tipoweek.html
