While popular, The rustoleum paints are poreous and will allow rust to continue. They have small pores like your skin that will allow air and water to reach the metal. Car wax was invented for poreous paints to seal them off from water and oxygen. There are paints and products out there that will completely eliminate rust. I gather from the posts most of you would not want to spend the money for them on a fence and don't mind the fading. But for those who want to know, he would need to use a converter such as Ospho on the rusted areas followed by an epoxy primer which is totally water proof stopping the moisture and oxygen from reaching the metal. Then for top coat an acrylic enamel or a urethane enamel will give you the longest lasting finish equivilent to the paint on a car. Steel Fuel trucks are painted with urethane enamels due to their superior resistance to fuel spills. The urethane is a clear coat mixed in with the enamel giving the paint a high gloss. Both of these have superior resistance to UV rays and fading. But require proper breathing equipment to spray. Rustoleum and other synthetic enamels such as Tractor Supply's paint for tractors have poor resistence to UV rays in addition to being poreous they fade to a dull then chalky appearance. Much like you see on farm and landscape trailers after a year or so. If you did at least use the Ospho converter the rust would stop if you used an epoxy primer over the ospho. Then if rustoleum top coat was used, you could just repaint as it faded without further rusting. The ospho is used by bridge maintaince and ocean going ship painters on rust. For anyone who wants to repaint a tractor or car etc, visit the paint and body board where you can learn and get great advice about the best materials.
