Tool Talk Discussion Forum
Where the oil drain plug?
300 Randy
10-27-2004 11:51:54
I have a yardmachine woodsplitter that I bought back in 99. Its a 5hp Briggs & S. I cannot for the life of me fine anyplace to drain the oil. The bottom of the engine is not accesible. Do I need to remove the engine or try to syphon the oil out of the fill hole. Thanks for the info
John *.?-!.* cub owner
10-28-2004 06:55:42
 Re: Where the oil drain plug? in reply to 300 Randy, 10-27-2004 11:51:54
I have a new Campbel Hausfeld pressure washer with a 6 horse Briggs on it, and there is no drain plug on it. The instructions for the engine say to tip it over to drain. A lot easier to do on a pressure washer than on a log splitter.
Maybe Too Late
10-28-2004 06:52:05
If you have used it a lot in these FIVE years, now is a fine time to be finding out how to change the oil. These engines should be changed after the first 5 hours and then a lot more often than 5 years. Good luck.
CNKS
10-28-2004 17:19:02
 Re: Where the oil drain plug? in reply to Maybe Too Late, 10-28-2004 06:52:05
Takes a while to get five hours on a pressure washer used only a few minutes at a time -- only took me 3 years.
Polish Mike
10-28-2004 06:08:00
Took me a few minutes to figure out mine. Look underneath and you'll see a plug with a square indentation that takes an extension from a 3/8" drive ratchet.
Steve-IL
10-27-2004 23:31:36
I have a B&S 5 horse horizontal shaft engine, a few years older than yours. The oil drain plug on it is a large set screw on the side of the base plate (where the bolt holes for mounting are located.) Hope this helps.
-Steve
MarkB_MI
10-27-2004 17:57:24
If they used a vertical shaft motor (which are cheaper, since they're used in lawnmowers), there's a good chance they neglected to punch a hole in the mounting plate for the drain plug. Or it's in the wrong place. Take the motor off, figure out where the drain is and drill a hole in the plate. If the drain is obstructed by the pump, you might be able to plumb a rubber hose to the drain.
Dannie
10-27-2004 15:37:43
If it is a verical shaft engine you may have to remove it the first time.I drilled a large hole in plate under drain hole after I had to remove the one on mine.Guess they did not thikk about oil change when they put engine on.
MAC,IL
10-27-2004 14:47:13
Maybe just have an access hole for the wrench. Take the motor number and go to the briggs/Stratton web site and see if you can pull the number up there.
CNKS
10-27-2004 14:06:56
It may be a plug with a hole that takes a large Allen wrench or the drive on a 3/8 rachet -- don't remember which is on my pressure washer. There is room to get it out, mine was sort of buried under the framework at the bottom of the engine. Took me a few minutes to find it.
