Tool Talk Discussion Forum
new floresecent lights t-8
34gpa
12-29-2004 10:14:47
I bought some 8 ft strip lights the other day, no bulbs, but I had plenty at home. Opened them up to run new wireing out and the ballast says T-8.Question is will this ballast run the old style bulb and if not what is the advantage of the new style because they are twice as high. Locals want $9 per bulb. Thanks
Kendall
01-11-2005 15:20:59
 Re: new floresecent lights t-8 in reply to 34gpa, 12-29-2004 10:14:47
Bit of interesting reading on the new T8 lamps-
The big news is that the ballast is electronic, the tubes use less energy, put out almost the same light.
buickanddeere
01-02-2005 10:14:25
Don't worry the T-8's will pay for them selves. Safer in the shop to as they won't strobe at 3600,188,1200,900 rpm etc. Better cold starts too.
txblu
01-02-2005 17:31:46
 Re: new floresecent lights t-8 in reply to buickanddeere, 01-02-2005 10:14:25
Are these the smaller diameter guys with the green caps? If so, the company where I work (er ah used to work, tee hee) just changed every bulb in the plant and that had to be in the thousands?
Building my new shop in a couple of weeks and that question came to mind.
Thanks,
Mark
Charles (in GA)
12-30-2004 07:08:02
Advantages, more light, no hum from the electronic ballast, less current consumed and less heat given off.
8 ft T12 fixtures tend to hum alot, very annoying. T8 should be virtually noiseless.
Charles
Bus Driver
12-29-2004 11:55:04
Can the older T-12 and newer T-8 tubes and ballasts be mixed and work. Yes, usually. Will they work well and/or long? Rarely. Read the ballast label and use only the lamp type and size listed for best results.
