ken hortman
01-23-2005 18:05:18
stud / bolt removel in reply to stuck, 01-13-2005 14:30:44
TECHNICAL INFORMATION CRONATRON WELDING SYSTEMS, INC. STUD PULLING PROCEDURE Cronatron Welding Systems’ ongoing Research and Technology is constantly providing new, innovative labor and cost saving products and procedures. Cronaweld 333 was developed as the “ALL IN ONE” ALLOY, providing high strength, crack free welds on all types and combinations of steel. With its instant arc and spatter free flux coating, Cronaweld 333 is also the ideal choice for removing broken bolts, studs, pins, easy-outs, taps and drill bits. Cronaweld 333 eliminates the requirements for inventory of special “stud pulling electrodes”, left turn drill bits and turn outs. ELECTRODE: Cronaweld 333 (Cronaweld Eagle 3330 can also be used for the Stud Pulling Procedure and may be preferred for out of position work). DIAMETER/AMPERAGE SELECTION: The following chart provides technical information to insure successful stud pulling techniques. AMPERAGE SETTING: Due to variations in welding power supplies, set-ups etc., a test of the amperage setting should be done on a piece of scrap steel. Set the welding power supply for the amperage given on the chart, then adjust the amperage control as necessary to assure a stable arc while maintain-ing a very short arc length. PRE-WELD PREPARATION: The ground cable should be firmly attached to the work-piece. Position the workpiece in secure and stable man-ner. It is preferable to position the work piece so that welding will be done in the flat position with the elec-trode held vertical. The welder should insure that a com-fortable and balanced position can be maintained during the procedure. STUD PULLING TECHNICAL INFORMATION CONFIDENTIAL MATERIAL, REPRODUCTION, IN WHOLE OR IN PART, PROHIBITED Printed in U. S. A. (Rev. 4/ 98) DIA. OF BROKEN COMPONENT (INCHES) under 1/4 1/4 - 3/8 3/8 - 3/4 3/4 - 2 over 2 ELECTRODE DIAMETER (INCHES) 1/16 3/32 1/8 5/32 3/16 RECOMMENDED AMPERAGE (AC or DCRP) 25-45 40-75 70-110 110-150 150-200 TO BE READY AT A MOMENTS NOTICE, TO REMOVE ANY SIZE BROKEN BOLT, STUD, ETC. CRONATRON HAS PREPARED A SPECIAL KIT WITH ALL REQUIRED MATERIALS, AND INSTRUCTIONS. ORDER KIT CW3030. (Continued Over) WE 17.1 Corporate, Research & Distribution Hdqrs: 6510 Northpark Blvd. Charlotte, NC 28216-2367/ 800-843-0763/ www.cronatronwelding.com Return to Index
