Tool Talk Discussion Forum
thank you
robert1
02-26-2005 18:57:06
Thanks for you tips. I went to that web site also and found a lot of good info. I was able to get it figured out and seems to cut well now. The only thing is the cut is not perfectly straight. Near the bottom of the cut the blade wandered out about less than 1/8". I must still not have something quite right but am getting closer. Thanks for the help. I appreciate it.
Steve Crum
02-27-2005 13:49:22
 Re: thank you in reply to robert1, 02-26-2005 18:57:06
Your wandering cut may be caused by feeding a little to fast for the hardness of what your cutting. Even my big Kalamazoo saw will do this.
Run your blade guides as close to the cut as possable and slow up a bit.A decent cutting fluid doesn't hurt either. A dull, damaged or incorrect blade will screw up a cut faster than anything.
A common rule of thumb is to have 2 teeth in the cut at the same time.
I had a Harbor Freight bandsaw for a short time until I got the Kalamazoo, then gave it away. My ears still ring every time the guy uses that saw.
robert1
02-27-2005 21:20:17
 Re: thank you in reply to Steve Crum, 02-27-2005 13:49:22
Thanks for the info Steve. I'll give it a try.
