Tool Talk Discussion Forum
sthil saw wont start
pperry
03-24-2005 19:40:04
i have a 2 year old sthil 280. it has spark and getting gas. can anybody tell me what the compression is supposed to be . i hooked up a gauge, held the throttle open and pulled it 4-5 times. its reading 90psi
pperry
03-25-2005 17:50:38
 Re: sthil saw wont start in reply to pperry, 03-24-2005 19:40:04
i took off the muffler today, and after a few pops it started right up, i put it back together and it seems to run great. ill go back out tomarrow and cut some wood and see if it stays running while hot and under load.
JT
03-25-2005 14:22:14
Had rep tell me few weeks ago that these new saws need a minumum of 110-130# compression to run right. The rule of thumb used to be 90#. Newer saws run higher compression, higher RPM. You need to take off muffler and check to see if cylinder is scored, sounds as though it maight be the problem. I see this a lot in saw where gasahol is used. Alchohal is a solvent and if you happen to overchoke the saw to start, it will wash the cylinder lubrication and then the scored cylinder and piston appear. My .02 worth
shoe
03-25-2005 05:58:56
Check and see if the spark arrester screen in the muffler is clean. If it is pluged that could be the problem as it puts too much pressure against the exhaust reed valve.
randy
03-25-2005 07:54:39
 Re: sthil saw wont start in reply to shoe, 03-25-2005 05:58:56
no reed valve in a 280 stihl compresion is way too low
Boog
03-25-2005 07:25:48
I have had a saw not start because of a sooted up spark arrestor screen; cleaned it and and it fired right up. Also not noticed the chain brake lever engaged a couple times and pulled and pulled in frustration.
randy
03-25-2005 05:54:31
It takes a at least 100 pounds of compression to fire gas in a 2 cycle engine--new that saw would have about 140 to 150 . pull your muffler off and check your piston for scoring . Randy
CARL GREY
03-25-2005 05:48:12
SINCE YOU HAVE TRIED SEVERAL PLUGS AND I TAKE YOU HAVE TESTED TO SEE IF YOU HAVE SPARK YOU MIGHT HAVE BIG PROBLEMS. REMOVE THE MUFFLER AND TAKE A FLASHLIGHT AND SEE IF CAN SEE SCRATHES IN THE CYLINDER, ON A SAW YOU CAN HAVE GOOD COMPRESSION BUT IF THE CYLINDER IS SCOURED IT WILL NOT PUMP FUEL INTO THE COMBUSTION CHAMBER, GOOD LUCK
TomTX
03-25-2005 05:14:20
Have you cleaned the air filter. My 026 Pro won't start when the air filter is clogged.
caseman2
03-25-2005 05:04:07
When you pull the plug out is it wet? I've worked on several stihl saws that the muffler, or the exhaust ports were plugged. pull the muffler and look at the exhaust ports, if they are open and clean try starting it with the muffler off. If it starts with the muffler off then take a torch and burn your muffler out. hope this helps
pperry
03-25-2005 04:51:53
i run bosch plugs in my saw. i have tryed 2 new plugs, still doesent even show any signs of fireing. sprayed gas in cylinder, and carb still nothing
JT
03-25-2005 14:17:10
 Re: sthil saw wont start in reply to pperry, 03-25-2005 04:51:53
We quit using Bosch plugs, had trouble with them, went to NGK, not a problem one. Had new Bosch plugs bad out the box, brand new.
FarmerDave
03-25-2005 14:39:06
 Re: sthil saw wont start in reply to JT, 03-25-2005 14:17:10
I had an NGK once. It had a little twist on top. Vibration made the twist on top loose. When the saw was hot, starting was real hard.
Van in AR
03-24-2005 22:34:03
Its probably either a bad plug or old gas, is the fuel fresh?
Van
Roy Suomi
03-24-2005 20:14:05
If that saw has a Champion spark plug in it,Take it out and throw it as far as you can into the woods.. I've run into many repair jobs where the plug will fire out of the saw , but not under presure of combustion. You can use any other brand of plug.I've seen too many instances where the Champions break down without any reason. I had a Gardner Denver air compressor with a continental gas engine. After a complete tune-up it ran beautifully [ twice ] then it acted like it wanted to start but just wouldn't catch. I went through everything, to no avail. Finally out of desperation I bought a set of Motorcraft plugs .That compressor started first time everytime for years after that.. good luck
2x4
03-24-2005 20:56:36
 Re: sthil saw wont start in reply to Roy Suomi, 03-24-2005 20:14:05
90% of all saw problems are solved with new spark plugs. We had a new Stihl that wouldnt start: it had never run. Bad Chumpion plug new from factory! Bosch WR6F plug works best of any I"ve tried.
Dave Roeker
03-25-2005 04:44:35
 Re: sthil saw wont start in reply to 2x4, 03-24-2005 20:56:36
The rule with spark plugs in old tractors is "ABC"...anything but Champions.
