Tool Talk Discussion Forum
torx type bolts
fireman3
04-01-2005 17:54:53
i was wondering what the tool is called to remove these bolts. the bolts look like a torx tool but with more points i would guess about12 points. the bolts are on u joints for the final drive of a wisc. vh4d
sonny2
04-02-2005 11:47:06
 Re: torx type bolts in reply to fireman3, 04-01-2005 17:54:53
If you are referring to the bolts that bolt the inner cv joint to the drive flange on a front wheel drive vehicle such as VW uses, they are called triple square. You were correct that they have twelve points. They come in 6mm., 8mm.,10mm., and 12mm. I have the 8mm. one to fit my VW Rabbit. My son has the 10mm. for his Audi. They are available from Snap-on. The prices are from the Oct. 2003 price list.
3/8 drive 6mm FTSM6E $20.65
standard 8mm FTSM8E 20.65 length 10mm FTSM10E 23.95
3/8 drive 8mm FTSM8LE 22.95
long
length
1/2 drive 10mm STSM10E 24.50
standard 12mm STSM12E 26.50
length
1/2 drive 12mm STSM12LE 27.50
long
length
hope this is what you are looking for
kidbob
04-01-2005 19:47:05
The bolts with the 12 point head are called ferry head and can be turned with any kind of 12 point wrench the same size as the diameter of the bolt.
NC Wayne
04-01-2005 19:18:45
If they have twelve points than you can take them out with your average, everyday wrench/socket/whatever. Wrenches, sockets, etc typically come in 6 point, 12 point, and 8 point (for square fasteners) designs. You can buy any one of them although the 12 point seems to be the most commonly available. I haven't seen a metric twelve point bolt yet, but that's not to say their not being made. Usually if it's metric it'll actually look just like a torx but the torx shape is external instead of internal. If by chance thats what you've got you can get a set of sockets to fit them from NAPA, etc. Hope this helps.
CRUSADER
04-01-2005 18:55:12
Hello fireman3,
Are these external? If they are external, that you are looking at, it sounds simular to the clutch bolts I have run accross on a few IH tractors and loaders. You will need a 5/16" box end wrench or socket to remove and install them with. Hope this helps out.
Jim
