Kevin Bismark
04-21-2005 18:34:01
Re: sub panel in remote building, bond neutral to in reply to buickanddeere, 04-19-2005 20:02:08
3 or 4 wires, if there is any metalic connection between the 2 buildings at all then you have to use 4 wires, cable TV, phone, water pipes, gas pipes, I usually just run 4 and then don"t have to worry about it, no matter what you do a ground rod (2 would be better) will be required as it is a seperate building the panel you have most likely has a main breaker so that can be the service disconect, I try not to use the 6 switch rule unless it"s really big expensive equipment, other than that if there are 3 wires you do the neutral ground bond connection, and if there are 4 you never do, so if you wanted a sub panel in your house, the sub panel is in the same building, so you would not have to pound a ground rod of course, and you would use 4 wires and would not bond the neutral and ground together, remember, thou shalt bond the service once and only once. This deal about the metal connection between buildings may not sound imporntant but had a service call at a place years ago, and they had a 3 wire going to a building with a metal gas line, had a real bad neutral connection, and the equipment ground on the furnace burned off when the guy was in the garage, and couldn"t figure out how that was possible, because he said that the breaker on the furnace was off, so think about it, you have a 3 wire, neutral and ground bonded in the garage, now a bad neutral connection back to the panel in the house, and now the neutral connection is trying to return to the transformer back through the equipment ground going to the furnace and then through the copper gas line to the house, and from the equipment ground on the furnace in the house to the main panel and back to the transformer think he only broke down and called us because he had tools burning up in his garage from the imbalance when he tried to use them..
