Tool Talk Discussion Forum
tig coolant
mike brown
05-19-2005 10:27:42
I made a steel coolant reservoir for my tig machine. I want to use pink rv antifreeze instead of water for corrosion resistance. Is there a problem with this idea that I am not aware of?
Thanks
Rod M1
05-20-2005 22:26:47
 Re: tig coolant in reply to mike brown, 05-19-2005 10:27:42
You will be just fine using it.
T_Bone
05-19-2005 15:49:26
Hi Mike,
RV anti-freeze propylene gylcol so I don't see why it wouldn't work the same as EG. There's a PSD guy that's using PG in his diesel with good results for about a year so I don't think nozzle plugging will be a problem.
T_Bone
