Tool Talk Discussion Forum
suggestions for a gas powered weedeater?
mech187
07-05-2005 15:06:30
Hey guys, I need to buy a gas powered weedeater to use on a five acre place in a development. Fence lines, around lagoon, house etc. Something middle of the range price wise. Any suggestions on brands/models? thanks
lucasss
07-10-2005 10:25:19
 Re: suggestions for a gas powered weedeater? in reply to mech187, 07-05-2005 15:06:30
i like the echo straight shaft trimmers. lots of accessories and 10,000 + rpms . truley a high performance machine that holds up. lucas
Big Jim
07-08-2005 03:01:15
Not exactly a weedeater but kind of. I just added a new tool to my arsenal. It is an Ariens walk behind line trimmer. Takes a 22 inch swath, you don't have to carry it, and it is 6 HP. Its not quite as agile as the traditional variety but it sure handles larger patches of weeds in rough ground.
Eddie in MI
07-07-2005 08:44:07
Stihl FS 110 with the bike handle. You can put just about any blade you want on it.
I've been using the same FS 76 for about 11 years (7 of those commercially) and it just keeps going.
Chris in Washington
08-06-2006 15:06:02
 Re: suggestions for a gas powered weedeater? in reply to Eddie in MI, 07-07-2005 08:44:07
I also have a Stihl 76 that has been running flawless since purchase. I use still on the job (chainsaws w/Seattle Fire Dept)and at home.
Phil in IA
07-07-2005 07:21:46
I use an Echo 2410 and have no problem over 4 years of hard use. Line or metal blade, No Problem. I also ues an attachment called a Bever Blade, Its a round steel blade with a saw chain around the edge that makes very short work of heavy brush and small trees.
Whatever Brand you end up with buy the best you can arrord. it will pay in the long run.
KenB in CT
07-06-2005 11:42:13
I just bought a Honda 4 stroke. Works well, lots of torque and it's not as loud as a 2 stoke.
hawaiirocky
07-08-2005 02:21:04
 Re: suggestions for a gas powered weedeater? in reply to KenB in CT, 07-06-2005 11:42:13
I also have the Honda four-stroke. Little heavier, much more expensive, but easy to start, cuts well, no fuel to mix, and is quieter for the amount of power. Get the optional cutting head that is easy to re-load.
mech187
07-06-2005 09:05:09
thanks a lot for the input guys. this website is the best place to find help!
farmweld
07-06-2005 06:42:54
ecoh, i use one semi commercially for my mowing business. make sure you get the straight shaft, no matter which one you get
farmweld
3010 Ken
07-06-2005 05:27:47
Morning Mech; Shindaiwa is really good.
Charles (in GA)
07-05-2005 18:47:56
Echo
lp gas only
07-05-2005 18:07:31
We have owned a Cub Cadet model CC4075 for about half a year or so and we love it. Anything you can find to cut threw it goes. Its a 4stroke and takes regular gas and what not. It has an array of attachments and can be very very useful. All great for about 200 bucks
Fawteen
07-05-2005 17:50:47
We rent Shindaiwa's at work. If it'll stand up to rental use, it'll stand up to anything. Lotta pro's use 'em too.
Ol Gray A
07-05-2005 17:35:49
Honda 4 stroke. more expensive but i have been using mine for 5 years with no problems.
e
07-05-2005 20:20:42
 Re: suggestions for a gas powered weedeater? in reply to Ol Gray A, 07-05-2005 17:35:49
I second Honda. I hear too many stories about people letting someone else use their weed eater (ie. kids, wife, brother, etc.) and they don't mix the oil with the gas. The 4 strokes make that mistake a thing of the past.
Chuck (VA)
07-05-2005 17:32:03
I have had an Echo straight shaft and have used it hard on 5 acres plus clearing fence line on our mountain retreat. Use both string and saw blade. Also recently bought a "Gator" attachment with stainless steel edged plastic cutters, which makes short work of briars and wild roses.
Have used for about 5 years. Had to replace the gas line once, easy fix.
MAC,IL
07-05-2005 15:47:04
Echo seems to do a good job. I have seen some real good stihl and red max also.
Rauville
07-05-2005 16:36:04
 Re: suggestions for a gas powered weedeater? in reply to MAC,IL, 07-05-2005 15:47:04
I'll second the Echo vote. I've had a straight shaft model for the past 8 years that has never failed to perform...either with string head or brush blade.
Davis In SC
07-05-2005 15:15:27
Robin
2x4
07-05-2005 21:54:07
 Re: suggestions for a gas powered weedeater? in reply to Davis In SC, 07-05-2005 15:15:27
gotta second the Robin brand; am using one 20-some years old with the 3-bladed knife.
