Tool Talk Discussion Forum
Old forney stick welder / battery charger
chuckinnc
08-03-2005 11:41:42
Im thinking of buying a old forney welder/charger
the guy that has it donent know anything about it. I cant tell by the pitcure if its ac & dc but if it is also a battery charger then wouldnt it be both ac & dc welder? Whats one worth?
Nathan L
05-23-2006 06:43:23
 Re: Old forney stick welder / battery charger in reply to chuckinnc, 08-03-2005 11:41:42
I just picked an old forney thats in pretty good shape except there is what looks like a battery inside that's no good. The guy I bought it from called it an "acid box." Anyone know if that's part of the charger or welder and if it's replaceable? Thanks!
Joe Nash
02-18-2007 08:40:23
 Re: Old forney stick welder / battery charger in reply to Nathan L, 05-23-2006 06:43:23
I just got a forney model cb welder. I is sunbaked bad. was wondering if anyone had a picture of the front so would know how to mark the connection holes. It has 5 down each side and 3 across the bottom.
Harold Ballard
06-02-2007 11:51:37
 Re: Old forney stick welder / battery charger in reply to Joe Nash, 02-18-2007 08:40:23
I am looking to buy a Forney welder like you are talking about. The front still has all the markings. Do you still need the pic? I want to know did you get yours to weld or not?
Abryan37
06-19-2006 15:10:28
I just got an old Forney welder for free from a friend of mine M# C6BT. I saw that part your talking about. It is a capasitor. Mines was leaking. I called Forney and they gave me a part # for it at Grainger ( part # 6X660 ) don`t use the welder if the capacitor is damaged. I am trying to get lititure on the welder. Any help from anyone?
Too Far Gone
08-04-2005 15:34:34
We have one of those welders bought new in 1956 and its still welding good,but it is only an AC welder.That batt. charger is wired in separate from the welder unit.Ive never seen a charger that still works.
Bill WI
08-04-2005 08:03:54
We too had a Forney , didn't have the charger, but it plugged in 2 of the heat range taps and did not use the ground. A garage used to clamp his batteries on this way without the charger , but must've known what he was doing and not for long. Would seem like they were charging batteries by induction off the coils, but don't know and maybe there was a rectifier in the charger. Ours was a 180 amp and there was a duty cycle on back of case with the voltage which would be a decal I believe on the case. Being a copper wound unit it was higher. The salesman said you could leave them weld continouse with them, but if you checked the manual it did have a duty cycle and on the low end was very high.
Joe(TX)
08-04-2005 05:06:27
I have 3 of these Forney welders. 2 have the chargers. They are about a good an AC stick welder as you can get. They have a good stable arc and a good duty cycle.
I bought one for $10 from a junk pile and the other for $50. Both needed the capaciter inside replaced (It's a motor run capacitor). It's about the only thing that goes wrong on these welders. The other welder I paid $100 for many years ago with all the accesories. I have seen them for as much as $150 .
RusselAZ
08-03-2005 20:05:15
The charger is the only part that is DC. These are really good welders and are almost destruction pruf. They don't really have a duty cycle like you will read about on newer welders. These box welders were built and designed for rural power supply way back when which brings me to my next line.
The best part about them is you can use the 180 amp setting all day and do it on a 30 amp breaker per leg. I have two of these, one has the charger and one doesn't. I bought my first one in 1974 and it was an old welder then. THe local Co-op in Nebraska had started selling Century welders and a farmer traded his in for a new one. About a month later he wanted his old Forney back.
I have a soft spot for the old Marquette's to. Bought one at a yard sale here a couple months ago for $50.00. A Forney that works is easy worth $100.
SM IN Wi
08-03-2005 15:25:43
I have a 3rd revised edition Forney arc welding manual that i got when i bought a box of old books. This book has all of the info of how to use the welder battery charger. If you would like me to scan the pages of the battery charger, e-mail me. PS sorry i will not sell the book.
Brian G, NY
08-03-2005 13:16:46
My Dad bought one back in the mid fifties and I bought one from the mid sixties. Both are very similar. 180 amps with a bunch of plug taps for selecting amperage. Strictly AC. Copper windings; a definite plus. I love mine but would like an AC/DC.
Bret4207
08-03-2005 14:58:58
 Re: Old forney stick welder / battery charger in reply to Brian G, NY, 08-03-2005 13:16:46
I thought about buying one of those add on rectifiers to get DC out of mine. Wish I'd been at the local auction where 2 Lincoln Ideal Arcs went for $100.00 each.
Bret4207
08-03-2005 11:59:51
Don't know aboout the charger part, but my Forney AC welder works great.
