Tool Talk Discussion Forum
empty R-134A tank good for anything?
jd Jim A
08-17-2005 22:15:36
Got an empty 30 pound R-134A refrigerant tank. Is it possible to make somthing useful, such as a air tank, out of it? If so, is it possible to adapt the threads on the tank fitting to a standard thread? Any ideas welcome!
welder
10-13-2005 08:47:59
 Re: empty R-134A tank good for anything? in reply to jd Jim A, 08-17-2005 22:15:36
Hi Does any one know if welding on these disposable freon tanks creates any kind of dangerous gas?? I can not find any information on this. The tanks are empty and purged.
lucasss
08-19-2005 19:38:05
when you put guages on a new 134a tank it has about 70 pounds of pressure.
Hobo,NC
08-19-2005 15:10:28
 pic's of a use in reply to jd Jim A, 08-17-2005 22:15:36
third party image
I plum'em up so I kin add a little air to'em and use it to push fluid in trans , rears etc. also use it to prime a engine oil system. also kin pull a vacuum on it and remove unwanted fluids
Turtle Traps..John,PA
08-19-2005 10:16:19
A fella down the road uses all of my empty 30 pounders for catch'n turtles for soup.
Tie a string on the handle, put a fish hook on the end of the string. Use raw bacon as the bait. Throw entire rig into the farm pond.
One day, when you do not see the empty can floating, rest assured you have a soup turtle on the hook.
I am not sure about the spca, though.
Hope this helps.
napaguy
08-18-2005 20:13:51
jim, did you ever want to melt scrap aluminum such as pistons?if so, do a google search for "freon tank" and "foundry". it is lined with fireclay. i plan on making one sometime. if not, it still makes for some interesting reading..napaguy
Joe in MN
08-18-2005 17:35:22
Makes a good target....
CJ-maybe
08-18-2005 14:23:00
Current tanks,after EPA regs took effect(venting,recovery,use,certification to buy,ect),can't be pumped into thru the factory valve.They have a green handle.Got to cut & tap or weld to it.Regs say recover,drill a hole & dispose.Also Fed regs about transporting refilled tanks(see side of can).That said,I know more regs-please don't kill the messenger.Personally I don't like the corrosion factor.
jake3x
08-18-2005 13:37:09
They make excellent hydraulic reserve tanks when adding hydraulic items as loaders etc.
T_Bone
08-19-2005 22:11:04
 Re: empty R-134A tank good for anything? in reply to jake3x, 08-18-2005 13:37:09
Hi Jake,
Refrigerant cylinders contain a 500psi rupture disc for a safety device when the cylinder has too much pressure. You can not use them on the high pressure side of the system.
T_Bone
jake3x
08-21-2005 08:26:08
 Re: empty R-134A tank good for anything? in reply to T_Bone, 08-19-2005 22:11:04
T-Bone I said reserve tank there is no pressure involved it only hold reseve oil and feeds the intake for the pump.
dr.sportster
08-18-2005 13:17:59
A coworker and I used to slice them longways in the horizontal band saw and weld little angles in to hold a piece of mesh for a mini portable grill.Actually that was freon tanks.Made a cute little grill for watching motocross races etc.Probably ingested some type of poison in the burgers,however,I didnt die yet.Since then a Taiwan grill would be alot cheaper than that and not worth the time and effort even with free welding gas and shop use.
Slowpoke
08-18-2005 12:07:43
If it's like a 20lb bbq tank, saw it in half below the center seam. Cut an 1-1/2" hole in the bottom and weld in a 3-4" length of pipe/heavy tubing. You will have a heavy duty, bullet proof funnel.
Do the same with the top for a different size pipe. A 3" pipe will fit a DWV sewer pipe access.
old
08-18-2005 08:43:38
I've used more then one of the to make air tanks out of. Only problem I ever had was the shut off valve didn't hold up well but for a quick fix of air it will still work well. Or you could also pump it in for a little more reserve on a lager compressor system
MAC,IL
08-18-2005 08:28:13
Around here you cant leave any kind of tank laying around, meth makers like them. Seen people lose the gas tanks right off the grills.
Glen in TX
08-18-2005 08:02:29
If refrigerant dealer won't take it scrap it. Heard of lots of injuries and people even killed from using those as air tanks. Use to be a common thing to see them sold that way but illegal now. Metal is too thin to chance much pressure.
kidbob
08-18-2005 10:24:07
 Re: empty R-134A tank good for anything? in reply to Glen in TX, 08-18-2005 08:02:29
The 134A has a higher pressure than most air systems. The problum comes when water enters with the air, then in time it rusts the bottom thin and explodes.
Frank P
08-18-2005 08:01:53
They used to sell a kit to convert them to a portable air tank. May not be available anymore,since common sense seems to have gone the way of $1.00 gas.
DH in Carolina
08-18-2005 05:14:14
Hello The only thing you can do with it ,after it is completly empty is to take a pick or axe and chop a hole in the side and discard it. DH
