Tool Talk Discussion Forum
stihl chainsaw clutch sticks
carter-h
08-20-2005 11:47:57
I need help with any ideas on what I can do to keep the clutch on a stihl chainsaw from sticking or locking up!!!! Thanks in advance....
ScottP
08-21-2005 15:07:35
 Re: stihl chainsaw clutch sticks in reply to carter-h, 08-20-2005 11:47:57
Carter
The bearings for the clutch may be full of saw dust or dirt. Remove the clutch, clean and relube the bearings. Scott
RayP(MI)
08-20-2005 16:27:11
Chain saw clutches are a pretty simple affair: A couple spring loaded weights which expand against the inside of a drum. If it"s sticking, probably spring broke, or parts are badly worn. Best suggestion is a replacement clutch assembly. Not very expensive.
