Well, they're certainly not going to be as strong as 4x6's that they used to build my barn, but I was 10' spacing. You may want to check your local code to see what is required first, because I'm thinking is going to have to be inspected at some point, and would sure hate to see you go through the trouble then have some inspector say "No". From my perspective, as a non-engineer, I'd say have been using 2x4's to build homes at 24" spacing for ions, and those homes stand for ions. I'd like to be able to say "yes" to your question, but an engineer I am not. I have 2x8 rat board around my base that formed the concrete. And I have 2x4's spaced every 2' up, starting from the ground, working towards the top. And of course by the time you mount your trusses across the top, will strengthen even more. Can tell you this for sure. Is a fella a few miles down the road whom put one up as you described, using 4x4s at 8' spacing, but about 10' on the wall heighth, and came out just fine. His looks just fine, and works just fine. Make extra sure you're square. Use treated lumber into the ground. And if you think or figure need 8' wide doors, go at least 10', if need 10' wide, go at least 12' - cause it's a pain in the butt when the tractor axle squeaks through by a few inches (and the duals aint even on yet), then you gotta take some down, widen the door opening, then make a wider door from what you took down. Who was the idiot that overlooked that - ME, MYSELF, and I, both doors. Don't forget to check with your code guy first. But I don't see a problem. Good luck. Mark
