Tool Talk Discussion Forum
thanks; i figured out the problem.....
deanop
10-17-2005 07:34:05
i thought the same thing about needing more airs...went back out this mornin and found that you have to loosen a nut on the stem, and turn the valve stem...turns out the slicks are not holding air now...oh well-its gonna look funny with rally wheels on it...
wyokid
10-17-2005 09:52:10
 Re: thanks; i figured out the problem..... in reply to deanop, 10-17-2005 07:34:05
If I remember most slicks only run 5-10 psi. Years ago a guy in a nearby town was airing up the slicks on a friends dragster and started daydreaming while the pressure was building-ended up exploding the tire and the rim took off the top half of his skull on the way out the door. Skinny rally tires are definitely the preferred option.
