Tool Talk Discussion Forum
South Bend lathe
37 chief
10-27-2005 10:02:38
I have a old south bend lathe. It has 1 7/8"-8 thread to holod the chuck on. I need to know where I might find a chuck with 1 7/8"-8 internal threads. Thanks, Stan
Fred Martin
10-29-2005 09:33:08
 Re: South Bend lathe in reply to 37 chief, 10-27-2005 10:02:38
Chief...thats kinda a toughy cause it is an odd ball size. Can you buy one of the blank castings from Enco and have a buddy use his lathe to chase in the 1 7/8" threads? Thats the cheapest way I know of...then you turn/face it to accept the new chuck and drill and tap for bolting on new chuck. A plain back chuck is available most anywhere new or used. I wouldn"t advise buying a three jaw used cause most of them have been used till the accuracy is going south and theres not much use for them then. Buy a four jaw new/used and take the time to learn to use it. If you ever get good at using it and a dial indicator...you"ll be glad you did. Fred OH
greenmech
10-27-2005 19:29:11
Try E-bay ,search South Bend or Lathes. Ron Mn.
dr.sportster
10-27-2005 13:35:22
Also MSC 1800 645 7270 web address;mscdirect.com
Earl-IL
10-27-2005 11:05:22
I would try ENCO 1-800-873-3626 .Earl
