Tool Talk Discussion Forum
sulfer smell in garage
phil lowe
11-02-2005 03:44:58
woke up this morninbg to a strong sulfer (rotten egg) smell in my attached garage ,,,using my sniffer the smell is strongest near where I am charging up a couple car batteries .Has anyone else had this happen ,,I've unplugged the charger and will see if it goes away ,,but I've charged batteries before and never got this smell..
Ralph - Ohio
11-02-2005 04:20:34
 Re: sulfer smell in garage in reply to phil lowe, 11-02-2005 03:44:58
Is it possible that one of the batteries has a shorted cell and therefore the other cells are being overheated when charging? This will cause a strong odor. The charger will probably indicate that it is still charging heavily after a period of time when a good battery would be fully charged.
phli lowe
11-02-2005 04:30:55
 Re: sulfer smell in garage in reply to Ralph - Ohio, 11-02-2005 04:20:34
problem solved ,Called a local battery place and they said same as Ralph ,,,battery was probalby bad ..First time I've smelled that smell from a battery ,,thank god it wasn't my septic field backing up as was my first thought ...
Thanks ralph..
rotten robert
11-02-2005 04:53:15
 Re: sulfer smell in garage in reply to phli lowe, 11-02-2005 04:30:55
Duh: That smell was hydrogen sulfide which does smell like rotten eggs or sulphur. It is best to charge batterys in a vented place as this gas is also EXPLOSIVE and all it takes is a spark and kablooie you just got a battery acid bath.
BTW did your battery charger come with an instruction manual?
phil.lowe
11-02-2005 05:24:02
 Re: sulfer smell in garage in reply to rotten robert, 11-02-2005 04:53:15
robert ,I'd like to thank you for your non- condesending response.
I'm sure your a wealth of knowledge and have read every instruction manual you have ever received.
I,not being as intelligent as you, neglected to read that manual,just plug er in and flip the switch is what I do.
P.S. Robbie your DUH! comment was uncalled for, and reminds me of my 11 year old son,who I expect it from!!
Ken Crisman
11-02-2005 06:44:53
 Re: sulfer smell in garage in reply to phil.lowe, 11-02-2005 05:24:02
That was very nicely put Phil . I always hated that duh crack . I smacked my teenage daughter in the mouth once for that . I know now that I could've been put in jail for it ; but she never did it again . I'm glad you found your problem with the smell . It would scare me too . Ken
Lil-Farmer
11-02-2005 05:37:51
Phil,
Your response to Robert was not too swift either. While I agree he could have phrased it differently, what he said was the truth. If you don"t know what you are doing, quit doing it before you blow up your self and/or one of your loved ones. If your eleven year old had unhooked one of the charger leads with all that gas around and created a battery explosion, he might never have said "DUH!" to you again in your lifetime.
Then you would think "there oughta be a law".
THINK! THINK!!!!
salser
11-02-2005 06:12:42
 Re: sulfer smell in garage in reply to Lil-Farmer, 11-02-2005 05:37:51
Actually, no, his post was not correct. Hydrogen Sulfide is not explosive. The explosive potential comes from the hydrogen gas generated from the electrolysis of water in the battery. I do, however, agree that the hydrogen sulfide smell is a good indicator that a lot of electrolysis of water is happening rather than charging of the battery.
Logan in S.E. Texas
11-03-2005 01:27:05
 Re: sulfer smell in garage in reply to salser, 11-02-2005 06:12:42
I beg to differ Salser. Hydrogen Sulfide IS explosive. I work in an oil refinery and we use hydrgen in our process to take out the sulfer. If H2S ever gets out of the pipes it is deadly to breath and if it finds an ignition source. It is part Hydrogen which is very flammable, and sulfer burns too. Even in small amounts it can cause a serious flash fire and or explosion.
Keith-OR
11-02-2005 06:58:06
Well put Salser, was wondering if anyone was going to put out the correct info on hydrogen gas being produced when charging ANY battery. And that was the potential for an explosion...Have a good day
Keith
T_Bone
11-02-2005 14:51:38
 Re: sulfer smell in garage in reply to Keith-OR, 11-02-2005 06:58:06
Hi Phil,
And since you could smell the hydrogen sulfide or is it sulfur dioxide, you can plan on all your tools in your shop rusting very bad. You might want to wipe them down with a oily rag before that happens.
T_Bone
upred
11-02-2005 16:30:42
 Re: sulfer smell in garage in reply to T_Bone, 11-02-2005 14:51:38
hydrogen sulphide also called H2s is a toxic gas that is generated by decomposing organic matter, such as manure and paper pulp, it can be fatal in high enough concentration in confined spaces. It has a rotten egg smell, not odorless like methane. sulfur dioxide has a slighly sweeter smell, but it still stinks, sulfur dioxide is more tolerable than H2S but is also deadly at lower concentrations. Just a little science FYI
Rick
T_Bone
11-03-2005 06:27:19
 Re: sulfer smell in garage in reply to upred, 11-02-2005 16:30:42
Hi Rick,
I was doing a plant remodel at Tree Top apple juice company back in the 70's and they used sulfur dixoide as a preservative under a hood. Of course the hood leaked like a seive.
I was horse for 6mths after that job and refused to go back on another remodel job the next year.
The crap we used to have to work in was amazing. Lucky to be alive.
T_Bone
Stan in Oly, WA
11-03-2005 23:16:54
 Re: sulfer smell in garage in reply to T_Bone, 11-03-2005 06:27:19
Hi, T_Bone
A friend of mine who is a retired welder (North Slope, Satsop nuclear reactor [the little engine that couldn't],etc)once expressed the opinion, "We sell our bodies too cheaply." I was asking him if he had had any parts replaced; he'd had more than a few.
I've had four relatively easy surgeries on my hands and wrists (two so I could get my hands open every time I closed them, two to get back the feeling in my right hand, and keep my left from getting completely that way), surgery to make my gut stop coming out of my abdominal wall, and I'm going to need work on my shoulder joint, and one or more new hips unless I can figure out some way to sit quietly for the next thirty years. At least some of these problems occurred or got worse while I was working for pay that would make our elected aristocrats in D.C. consider me the scum of the earth. We do sell our bodies too cheaply.
Anybody who works with his hands and back has experienced more discomfort and outright pain than anybody with a desk job can begin to imagine. I wouldn't trade, though, and I've had the chance. I'm proud of having earned my bad disposition honestly.
Stan
upred
11-03-2005 19:15:10
you, me and alot of others. a few years back we lost several members of the same farm family in a manure pit, one went in and collapsed the rest I think it was three or four went in after him and never made it out. I think it was over 20 yrs ago and it always sticks with me.
Rick
