Tool Talk Discussion Forum
advice for welding gray cast iron
52 Case SC
11-19-2005 14:11:21
tore up my center hitch on my 3 pt hitch plowing snow. broke the holes out the 4 bolts screw into.
I need to build the area back up by welding and plan on placeing steel inserts in them. Any pre cautionary advice for work on the cast iron block.
jerrycpp
11-25-2005 09:50:15
 Re: advice for welding gray cast iron in reply to 52 Case SC, 11-19-2005 14:11:21
I've had good luck using nickel rod. Grind a nice V on both sides of the break, clamp it all in place, and then heat it with a rosebud torch. Not red hot, but darned hot. Have someone else run the rosebud, as you want to keep the whole thing hot while you weld. The nickel rod will lay in there like butter. When done welding, immediatly use the pointy end of your welder's hammer and peck all over the welded area as it cools. This seems to help the molecules align and keep it from cracking. Peck a 4 inch long weld about 2 - 3 minutes, then let it cool very slowly. You can put the piece in ashes and leave it for several hours as it cools. Good Luck!
T_Bone
11-21-2005 14:29:34
Hi 52 Case,
Ya it probably can be repaired but to advise just what will be needed without seeing a picture will be difficult and probably be the wrong info. Post a picture in a new thread so it gets attention at the top of the forum page.
T_Bone
