There are several good units in the true 5 hp (thats about 23-25 amps If I recall) with two stage and 80 gal tank. Cheaper ones are splash lubed and pumps are rated for 15,000 hrs or so, probably more than the average non-commerical user will ever use. More expensive ones have pressure lube, better valves, better motor, etc. IR, Champion, Quincy, C-H, Speedaire, Dayton. www.tptools.com has very good units, but shipping will eat you up no matter who you buy from if its not local. Look at local deals if you can, so you can haul it home and save the shipping. Unless the compressor is going to run several hours a day every day, I would not get too hung up on pressure lube, auto drains, super duper this and that, buy a good brand and use it. I have a Home Depot Husky (a relabeled Campbell-Hausfeld) that is true 7 hp (mexican motor) and 80 gal vert tank and two stage pump (both american made) good unit about 24 cfm but C-H has changed the unit and the near identical looking pump appears to be China made now. Charles
