Tool Talk Discussion Forum
How to identify a 2 stage air compressor?
69zfarmer
12-16-2005 14:14:16
I bought a old 60 gallon air compressor from a guy and he said it was a 2 stage the compressor is a 2 cylinder "Keystone" brand name the cylinders are horizional 180 degrees from one another.It has a 1750 RPM 1.5 HP motor (single phase) it is piped like my single stage.How do you tell by looking?
XXXRogerXXX
12-17-2005 21:30:54
 Re: How to identify a 2 stage air compressor? in reply to 69zfarmer, 12-16-2005 14:14:16
If both cylinders have an air filter, it is single stage. If one cylinder feeds into the other, it is two stage.
Bob M
12-17-2005 07:04:15
Usually also the tubing connecting the low pressure (larger) cylinder to high pressure (smaller) cylinder is finned, and is located close to the fan on the flywheel to cool the air passing through it.
ldj
12-16-2005 14:53:55
2 ways.
1. 1 of the cylinders is smaller.
2. The larger cylinder is plumbed to the smaller one and it goes to the tank.
A 2 stage compressor is for high pressure, not volume. The larger cylinder is the one that takes air and compresses it, it then goes into the smaller cylinder for more compression.
Rod (NH)
12-16-2005 14:53:34
Hi,
One cylinder will be obviously larger than the other in a two-stage compressor. The smaller cylinder will be the second stage.
third party image Rod
