Tool Talk Discussion Forum
torpedo heater
paul
12-17-2005 08:52:10
Looking for a torpedo or Nipco type heater to warm up a shed now & then, melt out some machinery if ti gets froze up.
Any difference between kerosene models or propane? One better than the other?
--->Paul
Charles (in GA)
12-17-2005 09:27:09
 Re: torpedo heater in reply to paul, 12-17-2005 08:52:10
This was just discussed about a week ago. See the link to that thread.
Charles
Jon Hagen
12-17-2005 10:39:16
 Re: torpedo heater in reply to Charles (in GA), 12-17-2005 09:27:09
I have both,and find that the oil fired ones work well IF you use them in a well ventilated area. If you want to use them in a tight building,the oil fumes will kill you. Propane fired ones burn very clean,but the fuel tanks are a bit more hassel. The propane fired ones run on propane vapor,so you need to set the propane tank so a portion of the heater output warms the tank and keeps the propane vaporizing. If you do not,the propane will get so cold that it stops vaporizing and the heater will quit from lack of propane vapor pressure.
