Tool Talk Discussion Forum
stihl 026 won't run right ALL OF THE SUDDEN
TOOLHAWK
12-27-2005 16:00:10
Run great then it started slowly running rougher and losing power , it will start , kinda idles and runs about half throtle, changed gas , filter , air filter, plug ,been using saw the last month with no problems, this saw is like new,Can ya help!!! THANKS
Toolhawk
12-31-2005 06:08:07
 Thank to all it was the exhaust screen (pluged ) in reply to TOOLHAWK, 12-27-2005 16:00:10
It runs greeat now it was the exhaust screen, Thanks for all your replies . Ray
Tig welder
12-28-2005 03:05:34
 Re: stihl 026 won't run right ALL OF THE SUDDEN in reply to TOOLHAWK, 12-27-2005 16:00:10
Check the screen in the muffler,its more than likely full of carbon build-up..... .....Thats the first thing we do when we get a new saw..... .give that screen flying lessons..!!!
Logan in SE Tex.
12-27-2005 16:52:12
I agree with Too Far Gone. I had the same experience with my 026, cracked fuel lines, replaced same and made a world of difference. Cheap too!!!
Too Far Gone
12-27-2005 16:49:41
Please dont dick with the carb yet.Ive seen this very thing 3 times so far,twice on an 029,and once on my 039.The rubber fuel lines will crack and start sucking air.Replaced them and cured the problem,might help you also.Ive never once touched the carb on my Stihl Saws.
Skip
12-27-2005 16:20:30
Yep! I have a Stihl 029 that did much the same thing. Ran great for years (I cut about 8 cords of wood a year), then started slowly losing power. Took it to a qualified repair shop. Guy said spark plug was shot and carb needed rebuild. After repairs, ran GREAT!!
Chuck Davis
12-27-2005 16:18:50
Have you tried to adjust the carb? Tweeking the screws A little may fix your problem. I did say a little, my saw will on occasion need a slight adjustment. Do not mess with it if you are not familiar with 2 cycle engines. Lean it out too much and goodbye piston.
j meyer
12-27-2005 16:17:01
Its in your carb- clean that and it should be good to go.
