I'm really curious as to why the manufacturer does not specify and or prescribe a detail for anchoring the base plate. They most certainly had to design and engineer the hoist itself, and certify it for a specific rating. There must be shop drawings and a set of calculations on file for the product. What kind of anchorage did they include to certify the rating ? It would really seem that the manufacturer opens the door of liability by not specifying and providing an anchor detail, including reinforcing and or strength of concrete required. I don't mean to sound like a know it all or a jerk either, dont't get me wrong, but you are applying a max live load of 10,000 lbs. to what appears to be 2 columns, with 1' x 1' base plates, each column taking half the displacement of the load and transferring 5,000 lbs. to the base plate in compression. Also are there moment forces to consider with a vehicle on the lift, because it hangs over and beyond the centerline of each column ? I would want the manufacturer to provide an anchor detail, if a 5" slab calc's out, let them go on record stating it works based on an engineers calculation. To be quite frank, I'd not want to be wondering about something that is supporting that kind of weight. It should be designed according to the manufacturer. I would also think that something like a 2'-0" x 2'-0" x 1'-0" thick or similar column base footing with appropriate size anchors embedded in the footing would be necessary. This detail would not be a difficult task for an engineer to calculate what would safely displace the loads applied. Usually the footing for a column is below the bottom of a finished slab, they pour the slab over the footing, but make an isolation joint at the column line, cracks have tendencies to occur at the outside corners of these, I think that is what the isolation joint helps avoid. I can imagine the manufacturer must also have considered a customer who has an existing space with a concrete slab and is not building new, so they can sell the product that would bolt up to a slab, possibly using a larger baseplate, more fasteners, to displace it over a larger area, reducing the point loading. Again, don't mind me, I'm just thinkin aloud here !
