Tool Talk Discussion Forum
spanner socket ? - what's the real name
riverbend
03-13-2006 15:50:56
I am trying to remove the nut that holds the plate that the drive shaft bolts to on the transmission of a '62 BMW R50/2. The nut is round on the outside, but has four slots cut into the top - sort of like a castle nut, but with just four slots.
The tool must be like a 4 point socket with 4 pegs sticking out at the corners. Anybody know what the proper name is for this socket/tool ? It is very hard to find if you don't know what you are asking for.
Work arounds gratefully accepted.
Thanks
Greg
dr.sportster
03-14-2006 18:16:28
 Re: spanner socket ? - what's the real name in reply to riverbend, 03-13-2006 15:50:56
Its called BMW Matra tool 507.It should work on many different models including your bike.Is Capitol BMW still in busness?[Wash.DC]
riverbend
03-14-2006 20:11:03
 Re: spanner socket ? - what's the real name in reply to dr.sportster, 03-14-2006 18:16:28
Capital is still in business and probably has the tool. Ed Korn also has the tool. Actually Ed makes a nice, inexpensive set of pullers for working on the /2 motors. His transmission output nut socket is $50. A little steep for a socket that will get used once.
Honda does have a similar tool for their clutch basket. I even have one, but it is too big for this nut. I was hoping that this would be a specialty socket that could be bought over the counter.
dr.sportster
03-15-2006 14:28:17
 Re: spanner socket ? - what's the real name in reply to riverbend, 03-14-2006 20:11:03
Ive never done that job but you sound like you are winging it without the service manual.There are two other service tools you may need to do that job.I rebuilt a 1977 motor in 1978 [1000 cc] it had a rod seized to the crank.Ill take a Harley anyday over those sideways shakers.No offense and good luck.
riverbend
03-15-2006 17:19:35
 Re: spanner socket ? - what's the real name in reply to dr.sportster, 03-15-2006 14:28:17
Thanks for the good wishes. Actually, I have the service manual and the parts book. I am trying to wing it without investing in $500 worth of specialty tools. It's a long story. I'm doing as a favor for a guy who wants to get the bike going for a friend of his as a surprise. Both of them are customers of mine, neither of them are mechanics...
The BMW is a nice bike, but I'll take my Norton over it every day. I wouldn't mind one of those Buell XB900s.
dr.sportster
03-16-2006 16:07:11
 Re: spanner socket ? - what's the real name in reply to riverbend, 03-15-2006 17:19:35
Buell:103 horsepower:what the Sportster model Should have evolved to by now.
riverbend
03-16-2006 19:00:30
 Re: spanner socket ? - what's the real name in reply to dr.sportster, 03-16-2006 16:07:11
Should be the vrod motor by now. And why not put that motor in the Buell ?
dr.sportster
03-14-2006 14:26:44
It is a beemer service tool.Dont know where to get them since Amol Precision recently went out of busness.
Rustyj14
03-14-2006 08:30:22
That nut is designed to keep "shade tree mechanics" out of the works, and so you have to take the car to the dealer to have it repaired!
Dale B
03-13-2006 19:48:55
The nut is called a spindle nut, and they are usually used with a "French Lock " underneath . one of the tabs of the lock is bent into a slot on the nut to keep it from backing off.
Froid
03-13-2006 19:37:55
a claw socket or spanner nut socket or tool??
riverbend
03-14-2006 15:45:55
 Re: spanner socket ? - what's the real name in reply to Froid, 03-13-2006 19:37:55
It looks like the Honda clutch nut socket, any idea on the 'official' name of this tool ? The one I need has a 15 mm ID.
frankiee
03-13-2006 17:28:45
Link
Sounds like a special tool
Maybe contact the people above
Link
http://w6rec.com/duane/bmw/finaldrive/index.htm
slowpoke
03-13-2006 16:13:35
Could be a tool made just for that nut, special to BMW. Sorry, that"s the best I can do.
