Tool Talk Discussion Forum
straightening a bend tempered axle
jpuleo
03-21-2006 21:53:38
I have a old three wheel honda ATV. One of the rear axles is bent out of straight causing the wheel to wobble about 1". The axle is round and about 12" long. Im confident its tempered, Can I slowly work it back into straight with my hydraulic press? I know not to heat it with a really hot torch, but will it help to warm it with a handheld propaine torch? Any tips would be great.
Thanks
Joe
Hobo,NC
03-22-2006 05:00:36
 Re: straightening a bend tempered axle in reply to jpuleo, 03-21-2006 21:53:38
I have straiten out a bunch of’em, I put the ATV on my steel werk table and chain down one side , put a block of wood under the differential and use a long pipe to straiten the bent shaft., you are not gonna git it perfect but it will be close enough you will never notice it while ride’in it.. Make sure the stamped steel wheel hub izz not bent also.
ohio
03-22-2006 00:37:57
saw alot straightened in press, best to have lathe & indicator to check it, no heat! (i'm not telling you to try it, look for good one & use your judgement!)
Ron in Nebr
03-21-2006 23:56:53
Going along with Bob's reply down below(kinda)....go to ebay and type in a search for your model of 3 wheeler(ex- 110 Honda). My son acquired a Honda 110 and I needed a few parts for it so I checked ebay and theres a TON of people out there parting those things out, with every part you can think of up for sale. My guess is you'll probably find a good axle on there so cheap you wouldnt even want to consider messing with your bent one....hope this helps!
Ron in Nebr
03-22-2006 00:01:34
 Re: straightening a bend tempered axle in reply to Ron in Nebr, 03-21-2006 23:56:53
Oh, just to add to this- unless you have some kind of honda I'm not familiar with(which is possible) your axle most likely isn't 12 inches long. Those two big nuts on the right side of the housing just hold the sprocket or brake or something on....the axle itself in most of 'em is all one peice and goes clear through from one wheel to the other.
Stan in Oly, WA
03-21-2006 22:57:57
Hi jupuleo,
I'm sure you'll get more informed advice from others. This is outside my field of expertise and personal experience. What I've heard or read about the situation you describe leads me to believe that you couldn't use your hydraulic press slowly enough to safely straighten the axle with it. The rate for straightening tempered steel would be more like you would get with a 20oz ball peen hammer, never striking the metal hard enough to actually see movement.
I'd guess that you wouldn't use heat with this method, but that's all it is---a guess. I know that light peening is useful in relieving heat induced stress in weldments in some unforgiving metals, like cast iron. That's why I think it might be appropriate for tempered metal. I also remember reading about a machinist who took deflection out of a shaft in a large piece of industrial machinery by tapping it for eight or ten hours. He saved the company some huge amount in repair costs, and a lot more in avoiding lost production time. I believe that his supervisor told him that the company was so grateful that they had decided not to write him up for working overtime without prior management approval. (I made that part up, I don't know anything about the circumstances.)
Good luck, Stan
Bob
03-21-2006 22:33:16
The daughter of a classmate of my wife's was killed when the rear axle snapped on a 3-wheeler, and she spun out of control.
Do you REALLY want to mess with a BENT axle?
