Tool Talk Discussion Forum
steel roll pins
Sandy White
06-11-2006 12:37:57
any one tell me how to remove a steel roll pin to get the sprocket off of a starter.
msb
06-11-2006 20:54:36
 Re: steel roll pins in reply to Sandy White, 06-11-2006 12:37:57
Do yourself and buy a set of roll pin punches.Makes the job so much more pleasant.
Sandy White
06-11-2006 15:57:14
Thanks Guys I got it out with a punch.
Glen in TX
06-11-2006 13:37:12
Use some penetrating oil and as said the proper size punch. They make special roll pin punches that have a dimple on them to stay centered on the pin and most auto or tool places will have them. Support the gear with a notch cut out in some scrap wood.
Rockyhawaii
06-11-2006 13:30:51
I finally won a battle with a roll pin on a fifty year old forklift. Took a week of soaking with PB, broken punches and chisels, saw blades, and finally I resorted to the torch. One more to go.
Coloken
06-11-2006 13:21:03
The correct size punch. This is one place where the proper size is very important.
Will MN
06-11-2006 12:49:45
Can't you just punch it through ? Or is there something in the way?
