Tool Talk Discussion Forum
stripped lug nut
rodgernbama
09-07-2006 19:36:17
Anyone know a good way to remove a stripped wheel lug nut. It would only spin around when I tried to remove it. I have been trying to cut it off with hammer and chisel and it's pretty buggered up. It's on the front of a Jeep Cherokee.
RusselAZ
09-08-2006 19:38:23
 Re: stripped lug nut in reply to rodgernbama, 09-07-2006 19:36:17
Drill the stud out. They are easy to replace instead of eyes, fingers, blood etc. It isn't any good anyway.
Jiles
09-08-2006 09:35:21
In many cases if you pull out on the nut,via the rim, it will grab on the threads and come off. An impact wrench works good.
bradk
09-08-2006 06:31:42
I'm with jmixigo on this.Burn it out.I've done it many times.With nice alloy rims,use several layers of duct tape around hole to prevent clear-coat burn. ~brad
MikeCatthemuseum
09-07-2006 22:37:31
Die grinder with a ziz wheel, or rock, or burr... most anything including a cold chisel and BFH. You're gonna have to replace the stud by now anyway.
2x4
09-07-2006 21:24:37
on my '92 jeep cherokee I used a Stihl cut-off saw. a grinder should do it if you're near electricity
Les Mack
09-07-2006 20:09:23
Sounds like you need a "nut splitter". Carquest, Autozone, O'Reillys should all carry them. If'n they don't, I'm sure NAPA does.
jmixigo
09-07-2006 19:43:37
if its not off after 3 or 4 bleeding wounds I lite up the "blue point wrench".
or just take it to a tire shop an say "ya'll gotta problem"
