Tool Talk Discussion Forum
meat grinder sharpening
1jake2
12-13-2006 04:25:08
Anyone know the proper way to sharpen a meat grinder knive?
TimV
12-13-2006 04:41:58
 Re: meat grinder sharpening in reply to 1jake2, 12-13-2006 04:25:08
1Jake2: John PA has the best way, but if you're in a pinch, the usual method is to lay the blade flat on a piece of fine sandpaper on a FLAT surface (a table saw table is what we always used at home) and move it in a figure-8 pattern.
Bayou Dave
12-13-2006 06:07:37
 Re: meat grinder sharpening in reply to TimV, 12-13-2006 04:41:58
I sharpen both the blade and one side of the plate on a flat piece of sandpaper. On an old commercial unit you may have to build up the end of the auger (the side that goes into the motor) to assure good contact with the balde and plate.
Sharpening...John,PA
12-13-2006 04:35:56
Without having special equipment, you might consider taking the blades to your favorite grocery store and asking them to include your blade with their normal (pick-up and delivery) sharpening service that they use.
Most family-owned stores work out just fine.
Stay away from the big-boy stores, though.
The meat stores usually contract with someone.
HTH John,PA
Don LC
12-13-2006 05:09:08
 Re: meat grinder sharpening in reply to Sharpening...John,PA, 12-13-2006 04:35:56
My stepson likes to deer hunt.....now he wants to procces the meat hemself..... .where can I find a electric meat grinder?
Rod in Smiths Falls, ON,
12-13-2006 15:39:31
 Re: meat grinder sharpening in reply to Don LC, 12-13-2006 05:09:08
There are all kinds of them on eBay right now. I was looking for an add-on to the pto of my wife's new Kitchenaid 575 watt mixer.
Joe(TX)
12-13-2006 06:15:55
Lots of places have the smaller electric meat grinders. Northern Tool, Acadamy Sports, as well as most appliance stores.
HOBART..John,PA
12-13-2006 05:41:08
I see used grinders all the time that were traden-in at the HOBART(tm) shops.
They, Hobart(tm) make most of the equipment that you will see at the pro's.
Try HOBART in the larger city phone-book.
HTH.
