Tool Talk Discussion Forum
sa-200 welder governer adjustment
graygander
01-20-2007 20:24:54
Can't get the governer/idle control to work on my lincoln sa-200. It has the f163 cont. engine,the diaphram is good in the idler and the lever moves on the governer when you rev it up. I need to know the correct way to adjust everything to make it work the way it should. It was screwed up when I bought it and my tinkering with it hasn't helped. Any help will be greatly appreciated. Thanks
george md
01-20-2007 21:58:27
 Re: sa-200 welder governer adjustment in reply to graygander, 01-20-2007 20:24:54
If you unhook the idler the engine should run
1400 RPM , if not adjust that first. Idler is
hooked to over ride the force of the governor
and pull to idle. Set vacuum valve to the desired
delay time before idle, closed it will run at
1400 , full open it will idle as soon as you
lift the welding rod . Be sure you have the
lever with the coil spring in it on the throttle
shaft .
george
