Tool Talk Discussion Forum
help with electorlysis
1941 farmall a
02-22-2007 13:12:43
Today i was going to try the Electrolysis for the fun of it to see if any thing happen"s well nothing did i got the charger and ever thing i gotthe rust off one spot on the peace i was wanting to get free of rust and the other the same way well i put 7 gallons in about 3x2 space about 10 inches deep i put the watter in there frist and then put SUPPER WASHING SODA in it and put the - on the part and the + on the junk steel and turnd on my charger to 50 amps to just see and i did 10 and 2 amps and sat there for aobut 10 mins nothing i messd with the clamps that did not work. The charger is a auto one and i dont know if that has any thing to do with it or not. Dose any one know what is wrong i shure dont. Thanks a bunch Carson
1941 farmall a boy
02-23-2007 13:40:31
 Re: help with electorlysis in reply to 1941 farmall a boy, 02-22-2007 13:12:43
I got it going today the peaces of steel are about 10 or more inches long and aobut 7 or 10 inches wide. Look on the tractor talk form you will see me Thanks all
DeanO
02-23-2007 11:22:36
2/3 cup of soda should have worked in 7 gal. The more rebar or scrap the better and it should be reatively clean. If it didn't fizz at all it must be the charger
Nolan
02-23-2007 03:28:03
What was your junk steel like?
I learned that using a piece of rebar would not work. Far too small. Also the setup is hyper sensitive to rust buildup. It blocks the current flow and the whole thing shuts down then.
When I switched to a large piece of metal on the + side, like an old scrap saw blade, things lit up.
Ralph - Ohio
02-22-2007 18:57:16
I'd suggest trying a different charger. I have seen some chargers that won't supply any current at all unless they see a battery connected with some amount of voltage. It's supposed to be a safety feature to keep you from trying to charge a shorted battery which could lead to overheating and an explosion.
