Tool Talk Discussion Forum
Snap on collet style stud remover ?
1936
03-07-2007 12:24:20
Like learn of your experience on removing studs, the acorn nuts fit on JD trts casting with the snap on stud remover.
John in Ct
03-08-2007 14:20:29
 Re: Snap on collet style stud remover ? in reply to 1936, 03-07-2007 12:24:20
I only used my set once so far but expect to use it more!!! I used it on a JD #5 mower. There is a bolt that is used to tighten the lock if you hit a rock and the mower opens up. I needed to get the castle nut off and couldn't get a wrench on the bolt head ( It's in a corner of a garage) so I put the Snap-on Collet stud remover on the bolt threads and backed off the nut. It worked really slick.
oldrustycars
03-10-2007 21:14:23
 Re: Snap on collet style stud remover ? in reply to John in Ct, 03-08-2007 14:20:29
used one daily in a muffler shop. its the very best stud remover there is.
