 I always enjoy these questions regarding pole type and other buildings. The responses from all around are interesting because of the variables like soil conditions, connection details and associated costs. I've often thought of trying to figure a way to keep posts out of the ground, but it's never easy, nor cheap as I see it. I often thought that a precast concrete extension, the same dimension as the post designed to extend the end of a post via connection plates, for the depth of ground contact would be an interesting solution for posts that may prematurely succomb to associated ground moisure and subsequent decay. I'm sure there are foundation designs that may allow for post connections above ground, but higher costs will be associated I'm sure. Food for thought, how to improve the durability of posts set in the ground. Not the first to try figure that one I'm sure. I would think that you would need to set these into the ground to be stiff and brace as necessary, 12" auger ought to work if the soil is not too hard, if hard, try softening it up with water, rocks they are a pain to deal with. The detail around posts below ground, so many variables to consider, but heavily preserved wood is a good start. Plenty of decks are built on sono tube piers, but can you make a connection on top, brace the frame of the building and still make it stiff as if the posts were in the ground 4'-5' ? If the shell were stiff then it would seem like the same thing as setting it on a foundation, just need to anchor it down, not familiar with the options on that. With windload to consider, the anchor detail would have to be substantial. I've also realized that nothing lasts forever when it comes to buildings, and with my tendencies for overkill in an attempt to create something that will last a long time, kind of have to compromise a bit or nothing gets done LOL ! I set the posts for my latest fiasco, LOL, a 20'-0" x 32'-0" building, these were .40 or could have been .60 CCA P.T. 6"x6"x18' delivered in the late 70s and sat until last year, on their sides, out in the open, the result of someones project that never happened. The carpenter ants did several of them in but miraculously stayed within certain timbers and left the rest alone. Several years ago I retrieved them, then when ready to use, I treated the bottoms with creosote and old motor oil, had found a jug of creosote laying around and decided to use that and used motor oil, was nice and hot out, so they were dry and soaked it up nicely. I set them as deep as I could, I still have to bring the grade up, so eventually they could be 5 feet in the ground and still give me 12'-0" height, soil is well drained here and I used the same soil around them for packing, after a few heavy rains, they settled in and are stiff. Figuring that once the roof is on, with 2' or 3' overhangs, gutters and good surface drainage around, these posts ought to hold up as the ground moisture should be kept to a minimum I would think. I like utility poles, they seem to last a long time around here, power company is doing some major work on the easement through our place here and there are some not so old ones coming out, not sure if they will allow me to grab a few, but I'll take those anytime I can get em. I've always been savvy about finding useable materials and other resources, and these posts I used were no cost, neither was the late model hoe I used to set them except the fuel and grease have a pile of good used lumber from a demo job and some sawmills to check in with for other materials, so far the costs have been minimal, can't wait to get more done on it. Like doing demo work and finding good used materials, with the costs today, hard to ignore.
