601 Fuel tank shut off
Jon Freyer
05-06-2001 15:11:34
Pulled the fuel tank shut off valve due to clogging- No screen installed on the intake. I assue that there should be a cylindrical screen over this hole. Is this correct? any Ideas on where I could get just the screen?
Thanks
Richard
05-11-2001 04:05:59
 Re: 601 Fuel tank shut off in reply to Jon Freyer, 05-06-2001 15:11:34
Our local Tractor Supply sells a repair kit with orings and a screen I beleive. But the entire valve assembly was only $12.00.
Also, On my CA, I installed a 1-1/2" long tube in the petcock to keep from fighting rust, it worked great, however after doing so I'm wondering if accumalated water will increase the rust problem? Yikes.
albe
05-10-2001 10:56:33
My 621 and 641 both have a cylindrical screen on top of the valve inlet. They're held on with a small, round headed machine screw. Not sure if the screens are available separately. I can check to see if I kept the screen from the valve I had to replace. A screen came with the new valve. You can e-mail me to "remind" me to look. albe
