Tool Talk Discussion Forum
starter-alternator on riding mower
Hersel
05-25-2007 12:17:48
When running at full throttle, blades not engaged, meter show slight discharge. When blades are engaged it shows a large discharge at full throttle. What is the problem or how can I check?Thanks for the help.
buickanddeere
05-25-2007 20:13:25
 Re: starter-alternator on riding mower in reply to Hersel, 05-25-2007 12:17:48
Starter-Generator combo or separate alternator & starter? What brand and model of tractor?
Hersel
05-26-2007 06:40:13
 Re: starter-alternator on riding mower in reply to buickanddeere, 05-25-2007 20:13:25
Starter-alternator combo. 48" Poulan hydrostatic.
22 HP B&W.
Ken Combs
05-26-2007 15:40:17
 Re: starter-alternator on riding mower in reply to Hersel, 05-26-2007 06:40:13
Uh, I've never seen or heard of a starter/alternator combo. Better check what it has and come back with more info.
If it has a starter that engages the flywheel gear, it most likely has an alternator coil under the flywheel.
Hersel
05-26-2007 06:35:01
Starter-alternator combo. 48" Poulan-hydrostatic.B&W 22 HP Thanks
Hersel
05-26-2007 06:35:00
Ralph - Ohio
05-25-2007 16:37:05
If you can tell us what kind of mower and engine and if it has an electromagnetic clutch it might help in the diagnosis. On some engines a poor ground at the regulator/rectifier is a common cause of no charging.
Hersel
05-26-2007 07:00:21
 Re: starter-alternator on riding mower in reply to Ralph - Ohio, 05-25-2007 16:37:05
Electrosatic clutch and 22 HP B&W.
Ken Combs
05-25-2007 13:38:38
If it is an electric clutch, sounds like you have an alternator that is not charging. Slight discharge to run the ignition and/or lights, BIG discharge when clutch draw is added.
If it a alternator coil behind the flywheel, disconnect the leads for the regulator/rectifier and check for AC voltage on two leads. If you have that the regulator is bad, if not it is the charging coil.
Jim K
05-25-2007 13:22:25
Almost sounds like the circuit for the blade safety switch is shorted.
It's easy, should be one or two wires that go to a small switch mounted somewhere so that the blade engagement linkage makes contact with it.
