Tool Talk Discussion Forum
temporary paint booth
john niolon
06-17-2007 07:07:04
I"ve got a truck frame to paint for a "53 f-100 street rod project. Don"t have access to a paint booth and no room in shop to put up sheeting walls... I"m looking for some ideas/plans to fab up a temporary paint booth with either pvc or conduit frame and plastic sheeting walls that I can seal up good enough for painting and keep the dust/critters off the fresh paint... ventilation will be cross flow of course... I just need some ideas on how to build the frame.... any closet painters/street rodders out there ???
thanks
John
Joe (Wa)
06-18-2007 22:04:23
 Re: temporary paint booth in reply to john niolon, 06-17-2007 07:07:04
http://www.wikihow.com/Create-a-Paint-Booth-in-Your-Garage
Joe
T_Bone
06-18-2007 02:15:07
I built a greenhouse out of PVC last year to see what results I would get VS growing veggie's in the traditional garden style in the AZ winters. The GH growing smoked the traditional style growing by 10 times over and is why I will have a permanate GH this year.
Some observations using plastic sheeting. Every time the wind blows the sheeting will stretch over the frame. About 3mths latter and it's time to resretch the plastic. Plastic sheeting needs a brace every 4sft, I don't care what anyone says. It's very hard to 100% seal plastic. After watching a home improvement show, there's only one glue made for PVC sheeting and Liquid Nails makes it. Me I ran a wire down at the bottom then rolled the sheeting around that then stapled.
No4 rebar sunk 18" into the soil spaced every 2ft is enough to hold the frame down under any wind condition. I left 6" of rebar above ground then slipped the PVC pipe over the rebar and used a piece of wire tied to the rebar to a screw in the PVC for a hold down. This works well.
I used sch40 3/4 for a frame. That's just not heavy enough. 1"PVC would better with 1-1/4" ideal. The PVC wants to got into a quansit hut configuration when you slip it over the rebars.
For outdoor use, I would look at using T1-11 with 2x4 frame for about the same cost. That 12ft x 12ft GH cost me $125 and if I remember correct wood frame constrction was under $500.
A oiless compressor is under $50. I would read some articles about SCUBA gear for a through understanding of breathing air in tanks and piping.
T_Bone
mike6845
06-17-2007 20:28:56
Old:
Pls forward paint booth info
thanks,
Mike
mikedesc@mchsi.com
Butch(OH)
06-17-2007 18:43:00
My temp booth is inside the shop. I built it in a corner so I could use two existing walls for my booth. The other two walls are roll plastic or "vis-queen" as it is known around these parts. I simply stapled it to a ceiling rafter and cut it off about 1 foot longer than needed to reach the floor. I have 2" PVC duct taped to the plastic at the bottom. It holds the plastic down while in use and serves as the roller to wind it all up to the ceiling when not in use. The corner of the two plastic walls is held together with a couple pieces of duct tape but not exactly sealed as I enter the booth there. An exisiting window holds a 2" fan which exhausts the fumes from the booth. Since my compressor is isolated from the fumes I use it to supply my mask with fresh air so I am not depending on a filter fo ISO (paint hardeners) protection.
Over on the paint board here I was slammed for using a window fan, It is supposably going to explode. And for using my compressor for supplying breathing air to my mask. I guess oiled air is going to kill me if the explosion from the fan doesn't. All I know is I have used it for many years and can paint a tractor with out plucking colored buggers out of my nose for two weeks and can still breath due to not having ISO poisen in my lungs. Check out ISO poisening on the net and decide for yourselves if a shiney tractor is worth your health and if you want to spend half a years wages to eliminate ISOs from your breathing air the OSHA approved way or by my $10 method.
Stan in Oly, WA
06-17-2007 11:15:11
Hi John,
I've seen a number of semi-temporary greenhouses built out of 1" PVC. It looked to me like it was that grade which is below Schedule 40, but I'm not sure about that. Resembles a quonset hut in shape. You'd have to work out your own pattern for the lateral bracing; easy if 4-way fittings are available, less easy if you're limited to doing it with T's. I'm also not sure what you do about the wind problem.
All the best, Stan
oldfarmtractor
06-17-2007 09:50:11
Old,
I would like to see what you have. My email is my name plus @aol.com
Thanks,
old
06-17-2007 11:11:43
 Re: temporary paint booth in reply to oldfarmtractor, 06-17-2007 09:50:11
Just send me an e-mail and I'll send you the pictures. I always have my e-mail on here open
old
06-17-2007 08:27:12
Drop me an e-mail and I'll send you some pictures of a set up I use. Cost is less then $100 to build and takes about 15-30 minutes to put up or take down. It also works as a green house etc
Wayne Taylor
06-17-2007 18:25:29
 Re: temporary paint booth in reply to old, 06-17-2007 08:27:12
Old,
I too, would like a picture of your paint booth.
Thanks, Wayne
rev.taylor73@gmail.com
old
06-17-2007 19:51:09
 Re: temporary paint booth in reply to Wayne Taylor, 06-17-2007 18:25:29
Just drop me an e-mail its open as it always is on here. I buit it as a green house but it works good for a car post, kids shed cover for a tractor etc. etc. etc
Stan in Oly, WA
06-17-2007 10:18:55
Hi old,
I'd like to see it, too. I sent you an e-mail through Y/T. If there's no reply by tomorrow morning I'll put my e-mail address in a posting like oldfarmtractor did.
All the best, Stan
old
06-17-2007 11:08:18
 Re: temporary paint booth in reply to Stan in Oly, WA, 06-17-2007 10:18:55
You should have the pictures right now
Stan in Oly, WA
06-17-2007 11:25:01
 Re: temporary paint booth in reply to old, 06-17-2007 11:08:18
Hi old,
Got 'em. Thanks. What method did you use to fasten the ridge member to the ribs? How does it do in a brisk wind when it's covered?
All the best, Stan
old
06-17-2007 15:02:54
 Re: temporary paint booth in reply to Stan in Oly, WA, 06-17-2007 11:25:01
I just use tape or zip ties which ever I have on hand at the time. When I put it up I try to do it so the strong winds will hit the side and sort of roll right over it and so far I have never had any problems
Mike in Ohio
06-17-2007 08:17:37
John I did something similar a few years ago for a picnic. I took 1 1/4 pvc pipe and made a frame which we covered with a big tent that my mother in law sewed together from some cheap fabric. For the frame I used two tees in the top rail close together one pointing down for the peice coming up from the ground and another with about an inch of pipe between them pointing up at an angle for the peak. At the peak two tees again one pointed at each wall. At the bottom of the wall is a tee to connect the frames together length wise. You can make it as long as you need mine was 14' wide and 30' long. Take your time with the layout to get everything lined up right. Glue only the sets of two tees with the short pipe between them when you have the angles right for the pitch of the roof. Then when you are done with project you can easily disasemble and it will take up very little room and can be put back up very easily. As for the covering and ventilation I can't help much but I would think a heavy tarp would be the way to go. Good luck Mike
oldrustycars
06-17-2007 07:32:09
Car Craft magazine did exactly what you are looking for about 4 years ago. Maybe try their web site, or try ebay for a back issue.
