cement truck hydrulic pump
tinyy
07-04-2007 19:04:27
Have any of you worked on the older cement trucks?
I have a pump that was used to raise and lower the dicharge shoot .
I use it to run a snowplow on my tractor and I let the smoke out of the motor today and would like to find some info on it.
It has a small tank about 5"wide 8" long and 4"deep. Controll lever hits a solenoid to raise it and then just free floats down (one way cylinder) pump set on the bottom of the motor in the hydrulic oil on the top plate of the tank.
Any info would be appreciated thanks tiny
Roy Suomi
07-04-2007 19:47:30
 Re: cement truck hydrulic pump in reply to tinyy, 07-04-2007 19:04:27
You have a starter repair shop in town?? Most rebuild shops will work on these pump motors..
