Tool Talk Discussion Forum
Zink smink
Stumpalump
07-21-2007 16:28:41
Zink/phosphate is being removed from our oil and the GM addative has been recalled.Nobody will tell you if the AC delco stuff is similar. Shell Rottella is using less and some moble one is being made like their cheap competetors or so I hear. Does any body see a problem using the high zink content Moble One V-Twin oil in our most dear to us engines? Or maybe adding a quart or two to regular oil to get the zink back.
Ludwig
07-21-2007 19:33:54
 Re: Zink smink in reply to Stumpalump, 07-21-2007 16:28:41
Hate to sound like the school marm but its zinc and Mobil. The city in Alabama is Mobile.
Who says Mobil 1 has been reformulated?
I did a quick search over at Bob is the Oil Guy and found no such information. Those are the kind of people to jump on it.
As for Rotella, it apparently depends on the weight and of course the rating. If its SL you're still okay. If its SM, has a diesel rating and is Xw40 your still okay.
You could always add some assembly lube to the engine...
Stumpalump
07-21-2007 20:23:15
 source if its good in reply to Ludwig, 07-21-2007 19:33:54
Re: New motor oil wear problems on older engines
Yeah since Mobil 1 is not a true POA base synthetic anymore. They sued Castrol for using Hydrocrack, not they are producing the same quality oil. I've been running RP for a while now. It keeps my 4.0 at N.O.T. and it's a true POA.
_____ _____ _____
96 4.0 AX15 HP9", D44, 4.88's, Detroits, 37's
Ludwig
07-22-2007 07:59:56
 Re: source if its good in reply to Stumpalump, 07-21-2007 20:23:15
Hmm, more searching, nothing conclusive. I've found a couple sites that say Mobil has been reducing the percentage of PAO basestock over time but I can't find anything that actually proves that through analysis.
I do know that the 15w50 I've been using has been pretty consistant over the last year of analysis and the wear metals on my car are well within limits at 10,000 mile oil changes. I'm now planning on working up to 15,000 mile oil changes provided the analysis continues to be within spec.
I did email Mobil, it'll be interesting if they reply at all and if they do what they say. Probably just marketing malarky.
Ludwig
07-23-2007 07:12:59
 Reply from Mobil in reply to Ludwig, 07-22-2007 07:59:56
Thank you for your inquiry,
To meet the demanding requirements of today's specifications (and our customers' expectations) Mobil 1 uses high-performance synthetic fluids, including polyalphaolefins(PAO), along with a proprietary system of additives. In fact, each Mobil 1 viscosity grade uses a specific combination of synthetic fluids and selected additives in order to tailor the viscosity grade to its unique requirement. Mobil1 motor oils are still 100% synthetic in formulation.
-- Thank you for choosing ExxonMobil products.
If you need further assistance, please contact ExxonMobil at 1-800-ASK-MOBIL
-Matt Jacob"
Seems to say they're still at least a percentage PAO oil but not much else.
If you were using it in an engine where lack of ZDP would be a problem it'd be smart to run frequent oil analysis until you were convinced the engine wasn't eating itself...
