Tool Talk Discussion Forum
powder spray torch
630crazy
07-23-2007 17:42:16
I am looking into buying a spray torch; does anyone have a website or two that I can get more info? What are some of the brand names?
What brand(s) should I stay away from?
I have searched this forum and it seems that "Steve U.S. Alloys" has extensive knowledge in this department.
630crazy
07-26-2007 15:39:07
 Re: powder spray torch in reply to 630crazy, 07-23-2007 17:42:16
Thanks for all the input guys.
George I will get a hold of you when work/life settles down a bit.
Shaun Jewell
Earl-IL
07-24-2007 07:41:34
I have used one on cast repair for years I bought mine at a engine rebuilding show in Indy.It is a Maitenance Welding Alloys in California. 949-380-9679 $675 back in 2000. Good people to do business with.Call Mal Conrad at 319-573-2685 he has a good torch also.if you can't reach him there call 1-866-457-8975 REGIS Tool. Earl
Mike M
07-24-2007 05:51:43
Those systems are pretty neat. My cousin used to work at a shop that had one. Great for building up shafts and he even aluminized some manifolds and exhausts for our tractors and they are holding up really good. Just thought I'd bring this up as another market for your services if you get one to help pay for it.
135 Fan
07-23-2007 20:05:55
I believe most specialty welding rod companies have spray torches. I would try someone like Castolin Eutectic. Dave
NC Wayne
07-23-2007 19:09:03
We bought a spray torch sold through Cronatron about 2 years ago. I don"t know who they have making them for them but we"ve had no problems out of the unit. Depending on what your doing they have two different setups. I don"t remember the particulars but one they call a cold spray that works at a fairely low temp and the other that requires alot higher temps to use. The one we got is the high temp model and we"ve built up and remachined several parts using it with no problems. Beyond that I couldn"t give you any more particulars about our setup if I tried and as for any of the other systems out there I haven"t a clue. Good luck.
george md
07-23-2007 18:09:04
630,
Which system are you interested in , the fusible alloys or the metalizing ? I have both systems . Send me an email with a phone # as I don't type fast enough to answer all the questions.
george
