Tool Talk Discussion Forum
tandem axle trailer
bigr
10-07-2007 06:31:04
Not sure if this is the right forum but I need some advice on my 16' tandem axle trailer. The original owner never used the trailer brakes and they need a rebuild from the non-use. I'm a little nervous depending on the truck brakes when I have a tractor on this trialer. A buddy told me to redo the brakes with surge brakes. I'm not sure I understand the difference. Also, the former owner put good used SUV 15" tires on it instead of actual trailer tires. I want to replace them since I have trouble with holding air after sitting for awhile. What brakes and what tires? And what's the difference? Thanks in advance.
hd6gtom
10-08-2007 12:20:18
 Re: tandem axle trailer in reply to bigr, 10-07-2007 06:31:04
Check with your state on this one. I am hearing some states have nixed surge brakes on trailers of certain GVW ratings. After using both kinds for years I would go with electric. For me,a lot easier to work on, parts can be gotten almost anywhere. Buying parts for surge brakes can be impossiable
Leland
10-07-2007 23:19:03
I hate surge brakes bacause the trailers from the rental yard that I rent equipment from have them and they always hang up or it takes a few seconds to get them to release .for me electric all the way
gahorN
10-07-2007 17:52:10
P.S. And hydraulic or "surge" brakes also have the ability to be backed up without leaving the vehicle to deactive the braking system. The mentioned link will also demonstrate how.
Link
jokers
10-07-2007 18:09:15
 Re: tandem axle trailer in reply to gahorN, 10-07-2007 17:52:10
Does that link suggest the use of "free backing" surge brakes? That is an additional component that most surge brake equiped trailers probably don`t have. It`s also electric.
gahorN
10-07-2007 17:50:33
Standard electric brakes are either ON or OFF. Several modern "electric"/"electronic" trailer braking systems can provide a variable braking effort.
Anyone wishing a complete description of most modern trailer braking systems can read and view illustrations at:
Link
Nolan
10-07-2007 17:06:48
Surge brakes are hydraulic brakes. The master cylinder is part of the hitch. When the trailer pushes against the hitch ball, this pushes the plunger in the master cylinder, and applies the brakes on the trailer.
The nicest thing about surge brakes is they adjust themselves to the load, and fit onto any vehicle. A heavy load on the trailer will start to push forward on the hitch pretty hard when stopping your truck. So the master cylinder gets pushed hard, which applies the brakes hard. When it is all working, it works quite nicely. I personally tend to like them for mutt work. Where I"m using a trailer for all sorts of things, behind all sorts of tow vehicles.
Surge brakes tend to make backing up a pain, as you have to get out and lock out the brakes. Otherwise, when you push backwards on the trailer tongue you lock up the trailer brakes.
Also, surge brakes don"t do anything when sitting still. So if you"re sitting on a steep grade, only your tow vehicle is holding.
Electric brakes are electrical. They use an electro-magnet to pull the brake shoes against the drum, or the pads against the rotor. They are actuated by an electronic controller in the tow vehicle. This controller sends various amounts of electricity to the electro-maget, to apply various amounts of braking force.
The controller is tied to your tow vehicles brake lines, and senses the hydraulic pressure. The more hydraulic pressure it senses, the stronger electrical signal it sends to the trailer brakes.
Electronic brakes require you to manually adjust the signal, roughly akin to adjusting the volume on a radio. If you"ve got a heavy load on the trailer, you want a lot of braking force. If you"ve got a light load, you want little braking force on the trailer.
Electric brakes require a dedicated tow vehicle. They only work when hooked up to a vehicle with an electronic brake controller.
You can apply the brakes on an electic brake trailer by pushing a bar or lever or button on the actuator. This is darn nice at times. When sitting on a steep hill, the brakes are kept on on the trailer. This can be nice at times, especially when trying to take off with a manual transmission.
Tires
Trailer tires are almost universally bias ply, with extremely stiff sidewalls. This keeps the trailer from wiggling and swaying.
Car tires are almost universally radial, with soft sidewalls. They make lousy trailer tires due to the side to side flexing they allow. You can compensate for this by increasing tire pressure, but then you get a bouncing trailer.
Truck or SUV tires can work, as they can have stiff sidewalls. I happen to have a set of 6 ply truck tires on my heavy trailer, and they work just as well as a trailer tire. But by not means are truck or SUV tires inherently stiff sidewalled. You must check them yourself.
The heavier the load on the trailer, the more important stiff sidewalls becomes.
jokers
10-07-2007 17:39:30
 Re: tandem axle trailer in reply to Nolan, 10-07-2007 17:06:48
I`m sorry to say this Nolan, but electric brakes that operate off the hydraulic pressure in the tow vehicle`s brake lines haven`t been used in probably 20 years, maybe more..... ..... also hate to say this, but your info regarding trailer tires being predominantly bias ply is also outdated. I`ve got an equipment trailer sitting in the yard with radials on it and they are trailer service tires, not automotive.
The E range tires on my Dodge Ram 3500, which BTW are radials, have sidewalls that are plenty stiff.
Chris Jones
10-09-2007 18:35:43
 Re: tandem axle trailer in reply to jokers, 10-07-2007 17:39:30
Nolan is differentiating between electric and electronic brakes. My 2001 GMC owners manual mentions tapping into the master cylinder to attach a trailer brake controller. This would be the way to attach an electric brake controller. Electronic brake controllers use various types of inertial sensors instead of tapping into the master cylinder.
As far as his comment on tires he said predominantly not always. From what I've seen he's right.
gahorN
10-07-2007 16:24:16
Surge brakes will modulate according to the demand for stopping. Electric brakes are either ON or OFF and do not modulate. Light loads will SKID and heavy loads will NOT STOP as effectively as surge brakes.
Surge brakes for me. (I'm also a FORD guy.) third party image
jokers
10-07-2007 17:46:03
 Re: tandem axle trailer in reply to gahorN, 10-07-2007 16:24:16
Sorry gahorN but the better electronic controllers have been proportional for close to 15 years. Surge brakes have no advantages over electric and infact give up alot of control the way I see it. Ever towed a trailer that got snaky on you for whatever reason? With surge brakes your only recourse is to hit the accelerator and drive out of it, not for the faint of heart LOL. With electrics you simply tap the lever on the controller and the trailer will generally straighten out to where you can stop and fix whatever caused the snakiness. Surge brakes also fail to work well if the tow vehicle is much lighter than the load being towed.
maplehillfrm,pat
10-07-2007 09:07:27
hello, you will be a lot happier with the electric brakes,
[electric brakes are RIGHT NOW stopping ,, surge brakes work on the principal of when you apply the brakes ,, your truck will dip and that triggers the brakes to work according to the force pushing down on the tonuge}}
I am happy to hear of someone finally interested in keeping the public safe when hauling a trailer with a tractor on it,,
You can replace the whole brake system on each wheel, as a kit not very expensive you take the old backing plate off and put the whole replacement backing plate on that is loaded , has the brakes magnets the whole nine yards,,
the electric brakes will give you a lot more control and stopping power,,,,
as far as the tires,, you can use suv tires as long as they are the correct size and NOT passenger tires,, they should have a highner ply rating on them , I prefer class E,, they are heavy duty enough,, if you are replacing though with new,, the price is not that much different, may even be cheaper to just put on the trailer tires,,,
if you dont have a electric controller in your truck yet do yourself a favor and get the better digital reading type you will be able to tell how much pressure is going to the brakes at a glance,,,
hope this helps,, post back if you have any questions,, there are lots of knowledge here,,,
safety should be your main concern and it sounds like it is,,, next is chaining the tractor down correctly,, but that will be covered in the next lesson hahahahaha,,good luck pat
jokers
10-07-2007 09:05:29
Your buddy who told you to convert to surge brakes might as well have told you to convert to air brakes, it will be about that simple because you`ll have to plumb in hydraulic lines and a coupler as well completely change out the backing plates.
I`m also a big fan of electric brakes on a small trailer that isn`t going to be submerged, surge brakes are a compromised convenience item for boat trailers who`s operators are too lazy or forgetful to get out and unplug before going underwater, even the really heavy boat trailers have electrics.
It might be merely coincidence but all of my trailers have Goodyear trailer tires and I haven`t had any problems. If you are going to be carrying any weight at all I would recommend a trailer duty tire but I do know many people use a good truck tire with no trouble.
bigr
10-07-2007 15:08:12
 Re: tandem axle trailer in reply to jokers, 10-07-2007 09:05:29
Our tractor club has a enclosed trailer we use for raffle tractors. It has surge brakes and never goes near the water. ????? ?????
jokers
10-07-2007 17:50:47
 Re: tandem axle trailer in reply to bigr, 10-07-2007 15:08:12
bigr,
I`m sure that all manner of trailers have been outfitted with surge brakes, including a pop up camper I once owned. I only cited the boat trailer application because it is almost universal on trailers which carry boats under about 10K# from what I`ve seen. I just can`t explain the logic of using surge brakes on any other type of trailer, false security comes to mind.
jokers
10-07-2007 17:54:00
 Re: tandem axle trailer in reply to jokers, 10-07-2007 17:50:47
Ya know something else that is laughable? Trailer brakes need periodic manual adjsutment so no matter what sort of brakes the average nimrod has on their trailer, they probably don`t have any brakes at all! I assume that most of the posters to this forum do a cursory brake function check atleast at the beginning of a tow but how many people do you suppose just hook up and go, assuming that their brakes are fine?
suptscottyb
10-07-2007 07:58:57
There is a trailer and transport forum on this site. You might want to post it there? I prefer the modern electronic controls. That way on a panic stop, I can apply extra braking to the traiker with the hand device.
Grizz
10-07-2007 16:31:33
 Re: tandem axle trailer in reply to suptscottyb, 10-07-2007 07:58:57
Since I pull a 16' tandem trailer EVERY DAY, maybe I will chime in.
Go with electric. They are not all on or all off as some say. You can adjust your controller to any pressure you want. I hauled my loader to a jobsite today so I had it on near full. On the way home with the trailer empty it was set at nearly off.
Hook up a breakaway switch as required and install a battery with the small charger in the box and you are good to go.
gahorN
10-07-2007 16:53:05
 Re: tandem axle trailer in reply to Grizz, 10-07-2007 16:31:33
Grizz said: (quoted from post at 16:31:33 10/07/07) Since I pull a 16' tandem trailer EVERY DAY, maybe I will chime in.
The electric brakes are indeed either ON or OFF. Setting them for individual loads on different trips does not modulate them as for each and every individual braking application. If you stop HARD one time, but EASY the next time...the electric brakes are still either ON or OFF. Surge brakes will automatically apply a modulated amount of braking action tailored not only to EACH stop....but also to EACH LOAD (because the total momentum is determined by the braking effort.)
(not trying to be argumentive, just offering a detailed reason for my opinion.) third party image
jokers
10-07-2007 18:14:50
 Re: tandem axle trailer in reply to gahorN, 10-07-2007 16:53:05
Ya gotta check out some of the modern controllers gahorN. The earliest controllers with proportional braking used a weighted pendulum and slide switch to control the signal to the brakes. The newer ones are solid state.
BobReeves
10-07-2007 17:27:46
Sorry, electric brakes are NOT simply ON or OFF.. My controller adjusts the voltage to the breaks allowing for hard to soft breaking.. I would assume all modern controllers are the same.
