My 2 cents. First there are a gazillion type of drain fields. I live in Michigan and have an engineered field. When I lived in northern IL it was a totally different animal - a "bowtie" field with plastic drain pipe in trenches. Anyway, there are also a lot of configurations of tanks, in parts of Michigan it is now a law to have two tanks in a series (I do not have this). OK been in my house 16 years. Pumped the tank for the third time two weeks ago. When you have it pumped - stand there with a flashlight and watch and see what is happening and talk with the guy. A tank does a couple of things - heavy stuff sinks to the bottom where the inorganics sit and collect and never go away and the organics decompose (slowly). The middle is the liquid. There is a "skimmer wall" on the newer tanks or a pipe that acts as a skimmer. This allows grease and the like to float and draw liquid from somewhere, maybe a foot or so under the surfact to flow out to the drain field. So - for anything that goes in, something must go out. Hopefully - solids settle, grease floats, and liquids go out. As far as pumping. The solids will build up and decrease the holding capacity of the tank reducing settling time and resulting in more suspended solids going to the field - BAD. The grease and low density material will float and accumulate to the point where it will go below the skimmer and go out to the field - BAD. Therefore a tank needs to be pumped. How often is a matter you can only determine by looking at the tank and finding out how much guck is on the bottom and how much is floating. If the bottom or the top stuff gets to the field, time for a new field. Pumping is cheaper - here it is $160 for a 1,000 gal tank. How much you accumulate depends on what you put in it and how much. Obviously a couple without a garbage disposal will put in far less than a family of 4 or 5 with a garbage disposal (yes you can run garbage into the tank, but you will need to pump it more often). A big killer, overlooked is lint from the wash machine - this will plug things up quick. Put a mesh lint filter on the discharge of the washer and change often. That link messes things up in a drainfield. For what it's worth. Sorry bout the length. JU
