Chainsaw
3020mss
07-03-2001 22:33:35
I have a chainsaw that has a automatic chain/bar oiler... Problem is its excessive. While running it will drip oil from below and sling it like mad out the end. HELP... what do i need to do.???
Dan Troll
11-17-2003 15:36:46
 Re: chainsaw in reply to 3020mss, 07-03-2001 22:33:35
I have a McCullock M47 chainsaw that I need a carb. rebuild kit, could you please let me know if there is a place that sell the kit. Thank you very much.
Scott
11-15-2003 00:13:17
Take the bar off, there will be a little screen in a grove, its kinda hard to see, but clean that screen out and you might have to adjust the oiler on the saw. but clean that screen first . good luck.
Gus
07-04-2001 05:04:32
Got a manual? Or call a dealer. Some saws had an adjustment screw to control this. Use the recomended oil, not too thin. Don't set the adjustment ( if there is one) too light or you will burn up your bar real fast. I know, I did. Good luck, Gus.
Ray
07-04-2001 17:43:48
 Re: Re: chainsaw in reply to Gus, 07-04-2001 05:04:32
A lot of automatic oilers are set to use oil at the same rate as gas, if your saw is doing this then leave it alone if however the oil tank runs out before the fuel does check to see if it is adjustable. Remember bar and chain oil is a lot thicker and stickier than motor oil and will not run out as fast
Scott Green
07-04-2001 18:33:44
 Re: Re: Re: chainsaw in reply to Ray, 07-04-2001 17:43:48
Ray , I read your reply. Just backing up your facts. Scott
